speaker replacement
Old Mar 26, 2007 | 10:03 PM
chris.one's Avatar
chris.one is an unknown quantity at this point
Default speaker replacement
I have a 2000 Blazer 4 door 4x4. I need to replace the factory speakers. On the front doors, do I need to remove the whole door panel or does the plastic speaker grill pop off without taking off the panel?
Old Mar 26, 2007 | 10:32 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: speaker replacement
You have to remove the whole thing...it's one piece.
Old Mar 26, 2007 | 11:02 PM
chris.one's Avatar
Thanks. Any quick tips?
Old Mar 27, 2007 | 12:32 AM
hillbillyinOhio's Avatar
one screw in door handle. two bolts under the door pull. Lift out from the door and unclip any harnesses. If you break any of those clips, got to parts store and get a box of 15 for 5 bucks.
Old Mar 29, 2007 | 03:15 AM
nai0013's Avatar
nai0013 is an unknown quantity at this point
You could always disconnect em and buy some custom kick pods if you enjoy staging!!!
Old Apr 1, 2007 | 11:22 AM
kaejr's Avatar
kaejr is an unknown quantity at this point
What's up guys, kind of going through the same thing...do you guys have any links to any schematics or diagrams? I found the the screw in the door handle but cant find the bolts.
Old Apr 1, 2007 | 01:46 PM
what year do you have?? if you have 95-97, then there are no bigger bolts. just the screw in door handle and two under the little cover in the door pull. If you have a 98 newer, then look at the door pull/armrest, then look directly under it. there are two bolts right under that do in rught under the door pull.
Old Apr 1, 2007 | 02:03 PM
kaejr's Avatar
alright I'll do that. I have a 99 and I'm getting around to actually putting the sound system together and tuning it. Right now I have 2 Kicker comp vr 12's and I'm replacing the factory door speakers because there is distortion once I get in the higher volume levels. Shouyld I replace the speakers on the dash as well?
Old Apr 1, 2007 | 04:03 PM
just unhook em.
Old Apr 1, 2007 | 04:31 PM
blazinloud's Avatar
dash speakers are about preference, I like having sound coming dash. plus if the speakers arnt amped it really helps.
c3478493
Feb 3, 2014 02:56 PM
kennjame62
Apr 20, 2012 06:53 PM
bradly2795
Mar 28, 2010 07:40 PM
erobe387
Oct 31, 2009 11:13 PM
thanser
Dec 8, 2005 02:59 PM
