static in tweeters
Old Aug 7, 2015 | 08:27 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
Default static in tweeters
i have small infinity tweeters in my dash when the crap delcos went, ive had them over a year...lately ive been here clicking static only in the tweeters. this is with radio on ( havent tried mp3 or other sourced to see if its just radio or any source) i checked the connections of both tweeters and they were fine, nothing was loose. its not all the time but most of the time.
i tried researching it with no helpful results
any help would be great!!
Old Aug 10, 2015 | 11:18 PM
tenorsaxdude's Avatar
tenorsaxdude is on a distinguished road
Try with the other sources. Sometimes I find that tweeters relay the static picked up via the radio from power lines and traffic lights (Traffic lights for me have been the worst).
Hopefully its just that, but post back
Old Aug 12, 2015 | 07:17 AM
er0ck273's Avatar
This morning I tested my ipod as the source... Only a 20 min drive but no static noted....gonna drive around a week with ipod only see if any static comes back....but I doubt it....I know to check the radio adapter behind the head unit... And the antennas on tight...anything else I could check?
Old Aug 14, 2015 | 10:41 PM
The wire that connects the adapter to the external antenna as well. Check for damage or chafing
I'm going to bet the issue is at the adapter though, if the connection is even slightly loose, it will move and create static. I recommend wrapping where it connects to the factory line in electrical tape to ensure it stays solidly hooked up.
Old Aug 15, 2015 | 08:31 PM
er0ck273's Avatar
literally wrapped it in electrical tape yesterday,the static was lighter but still noticeable, i checkeed the top portion of the antenna line under the hood...looked ok, will have to follow it tmr and see where it leads into the firewall
Old Aug 17, 2015 | 06:07 PM
Good luck
Might also try other stations just to check
Old Aug 18, 2015 | 06:57 PM
er0ck273's Avatar
Good luck
most stations have the static some shorter than others, i forgot to tape one end of the antenna adapter, so i just did that i will have to see if that worked
Tippman7641
Jan 26, 2008 09:43 PM
pimpinblazer91
Jan 24, 2008 07:49 PM
JLaw
Suspension Tech
Mar 26, 2007 05:09 PM
Daytona
Mar 25, 2007 02:46 PM
blazinloud
Aug 20, 2006 06:10 PM
