sub amp wiring
Old Feb 21, 2014 | 03:58 PM
big94fixup's Avatar
big94fixup is on a distinguished road
Default sub amp wiring
I'm going to install a powered sub in my KBlazer where the spare tire goes. What is the best way to run the 8ga. power wire? Above the door, under the sill plate or other options?
Thanks, Al.
Old Feb 21, 2014 | 05:03 PM
99bblazer99's Avatar
99bblazer99 is on a distinguished road
drill a hole In the fire wall and run it under the carper to the back
Old Feb 21, 2014 | 05:05 PM
richphotos's Avatar
how much power are you running? 8 gauge seems a bit small unless you are not running much power.
But, there are many places on the firewall that wont require you to drill a hole, you can run it through the gromet of another wire bunch. Then run it under the carpet.
Old Feb 21, 2014 | 07:14 PM
big94fixup's Avatar
It's just an old 80 watt bazooka. I guess under the carpet could be an option if I had carpet! LOL I'd rather go behind some trim but it looks like a hassle. Anyone done this? What am I in for?
Thanks, Al.
Old Feb 21, 2014 | 07:17 PM
8 gauge is cake to work with. it will go behind trim no problem
Old Feb 21, 2014 | 07:30 PM
big94fixup's Avatar
Thanks, 99! Just tuck it in? Never thought of that, duh.
Al.
JohnBarJB
Sep 28, 2020 07:34 PM
bfsmith72549
Nov 1, 2010 05:44 PM
sifd4x4
Oct 5, 2009 09:13 PM
Canadian88
Feb 25, 2007 01:47 PM
Canadian88
Nov 14, 2006 05:35 PM
