sub angles
Old Nov 9, 2008 | 08:36 PM
  #91
NVANZEE's Avatar
Default RE: sub angles
i still have some time yet, i need to do the sound dampening first which i have ordered. So i will probably start on it sometime in january. i just want to get it all drawn up so i know exactly what im going to need.
Old Nov 9, 2008 | 09:19 PM
  #92
bobditts's Avatar
bobditts is an unknown quantity at this point
I would recommend putting the deadener on when the panels are warm. If you live in a cold area, use a heat gun to heat up the panels, or wait till a warm day. Ill get you the dimensions as soon as I can.
Old Nov 9, 2008 | 09:48 PM
  #93
NVANZEE's Avatar
ya ill be doing it in the garage with the space heater now that its insulated. It snowed for the first time this fall today, (it sucks)
Old Dec 15, 2008 | 08:53 PM
  #94
NVANZEE's Avatar
is this a good amp for powering my two rear speakers that have 150rms each. http://www.woofersetc.com/index.cfm?...roduct_ID=6274
then ill use my other amp for my front two speakers
Old Dec 16, 2008 | 06:43 AM
  #95
bobditts's Avatar
im not a hifonics fan, but for rear speakers that will do just fine
Old Dec 16, 2008 | 05:26 PM
  #96
NVANZEE's Avatar
ok, if i have a fused distro block do i still need an inline fuse in between the battery and distro or between the distro and the amps?
Old Dec 16, 2008 | 06:05 PM
  #97
bobditts's Avatar
always fuse the power wire within 18 inches from the battery. Just get a distro blcok that you can put fuses in and buy fuses rated the same as those on the amp itself.
Old Dec 16, 2008 | 06:32 PM
  #98
NVANZEE's Avatar
ok for my big three i have an open spot in my distro which will be as close to the battery as possible. should i use the open spot or leave it and go directly from the battery. If i use the open spot in the distro what size fuse would i get.
also what size speaker wire would you recommend for the pdx1000? For the remote turn on wire will i have to run one for each amp or can i go from one amp to the next? what size wire for this?
Old Dec 17, 2008 | 08:12 PM
  #99
NVANZEE's Avatar
also for the set up im going to have is it close to needing 2 batteries. The reason i ask is because i have a brand new interstate that isnt being used. so i thought i might add it too my setup.
Old Dec 20, 2008 | 09:08 PM
  #100
bobditts's Avatar
you wont need 2 batteries. You only need more batteries if you plan on powering your system with the vehicle turned off, or if you have a very power demanding vehicle while in idle. Dual batteries is a big pain in the butt, especially if they are different brand, type orage. you have to buy a battery isolator and wire everything up properly. Not worth it unless absolutely necessary.
power wire should be no larger than 4ga, and no less than 8ga depending on how long the wire needs to be. remote wire should be no larger than 18ga. How many amps will be needing a remote wire?
The big 3 power wire is really your preference. Either way will work just fine.
