sub angles
Old Oct 14, 2008 | 10:11 PM
  #81
bobditts's Avatar
bobditts is an unknown quantity at this point
Default RE: sub angles
whats the file size of the inventor dwg?
Old Oct 16, 2008 | 06:40 AM
  #82
NVANZEE's Avatar
223kb
Old Oct 20, 2008 | 07:32 PM
  #83
NVANZEE's Avatar
how many rolls of the raamat would you recomend. i was think 3-4 rolls. do i need to get the foam too or not if i do how much i was thinking around 10 or so yards
Old Oct 27, 2008 | 09:52 PM
  #84
bobditts's Avatar
OK, so Autocad kicked my butt. I couldnt remember most of my 3d commands. Its been a LONG time. So, I did the next best thing, drew up the sketch free hand.
Basically, the amps are on angled wood pieces covered by a curved piece of very thin plexi. Have a wood lip on either end and bend the thin plexi under to hold its shape. Stictly for looks only.
You third amp will be hidden behind the curved amp rack along with all of your wires and fans, etc. Make sense?
Old Oct 27, 2008 | 10:18 PM
  #85
NVANZEE's Avatar
looks good but how would the amps be held in place. I know they will be on the angled wood but how is the wood supported? It also cuts down on airspace since the center wont be usable because of the thin plexi
Old Oct 27, 2008 | 11:03 PM
  #86
bobditts's Avatar
The amp rack itself could be made out of 3 angled wood pieces fit together to make the "curve". Any of the space underneath it could be used for the enclosure if necessary. I can get you exact dimensions if youd like. then you could plug them into inventor and calculate your airspace.
Old Oct 27, 2008 | 11:38 PM
  #87
NVANZEE's Avatar
i think i understand. dimensions would be great. Thanks for all you help btw
Old Nov 3, 2008 | 07:52 PM
  #88
NVANZEE's Avatar
hey do you have the dimensions. I also plan on ordering the raamat this weekend
Old Nov 9, 2008 | 11:06 AM
  #89
NVANZEE's Avatar
so is there a flat board that the amps mount to with curved plexi over it?
Old Nov 9, 2008 | 06:38 PM
  #90
bobditts's Avatar
Hey bud. I didnt even see your last post. Sorry I didnt respond. No dimensions yet. Sorry. Been a bit busy. How soon are you looking to build the thing? and yes, the amps will mount to flat surfaces with a curved plexi cover making the illusion that they are on a curved surface.
