sub angles
Old Dec 21, 2008 | 11:43 AM
  #101
NVANZEE's Avatar
Default RE: sub angles
i will have 4 amps for the remote, the 2 pdx amps and the 2 speaker amps. What size fuse should i get for the distro if i run a wire for the big 3 out of it? As big as i can get? Also what about the speaker wire?
Old Dec 21, 2008 | 12:19 PM
  #102
bobditts's Avatar
bobditts is an unknown quantity at this point
you do not need a fuse from your alternator to your battery. the electrical flow is only one way (from the alt to the battery) and it fluxuates constantly.
You will need to use a relay for your remote turn on wire. Run 1 wire from your head unit to the relay then branch off into 4 after it.
you do not need a fuse for your speaker wires. As far as speaker wire size, anything larger than 16ga is overkill. Basically anything larger than the tinsel leads is overkill unless you are a super heavy SPL competitor.
Old Dec 21, 2008 | 09:54 PM
  #103
NVANZEE's Avatar
my battery to alt wire will be coming out of my distro block. so i need a fuse. How are these for RCAs http://www.woofersetc.com/index.cfm?...roduct_ID=5998 2 per speaker amp and 1 per sub amp.
Old Dec 21, 2008 | 10:10 PM
  #104
bobditts's Avatar
link isnt working. My stock fuse on my alt in my sedan is 120A. Should be safe with that in yours too.
Old Dec 21, 2008 | 10:27 PM
  #105
NVANZEE's Avatar
ok. fixed the link
Old Dec 22, 2008 | 06:35 AM
  #106
bobditts's Avatar
if you spend that much on RCAs I will find out where you live and personally slap you. Go to knuconcepts.com and buy an amp kit from them. They should come with RCAs. All you need are RCAs that are shielded - nothing fancy.
Old Dec 22, 2008 | 06:55 AM
  #107
NVANZEE's Avatar
ok lol. I was kinda thinking they were over priced and i figured you would suggest something different. Thanks
Old Dec 25, 2008 | 09:33 PM
  #108
TehFattie's Avatar
TehFattie is an unknown quantity at this point
This is easy...
Alpine Type-R 12" subs.
Massive Audio P1500.1 or MA Audio HK401SX. With the 12"s, that Massive which is rated for 1500RMS @ 1Ohm will put out closer to 1700 or 1800RMS with a 0 gauge power and ground. The HK401SX puts out 1800RMS at .5Ohm. Friend of mine runs them on 2 Type-R 12"s at 1Ohm with 1200RMS and they sound good, just not at potential.
If you want to save money on everything, my friend is looking to upgrade from the Type-Rs. I could ask him for his price + shipping.
Old Dec 26, 2008 | 04:31 PM
  #109
blazerbumpin's Avatar
blazerbumpin is an unknown quantity at this point
face the woofers up with the port facing back
Old Dec 26, 2008 | 04:59 PM
  #110
NVANZEE's Avatar
i already have my design and system picked out. Thanks though
