sub box
Old Feb 12, 2009 | 07:19 AM
kpianka's Avatar
kpianka is an unknown quantity at this point
Default sub box
want to build a 15 " single sub box for my blazer just wanted to know the dimensions and should it be vented
Old Feb 12, 2009 | 01:00 PM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
Default RE: sub box
ok? uhhh not alot of info there.
Old Feb 12, 2009 | 03:29 PM
BudRacing's Avatar
BudRacing is an unknown quantity at this point
Default RE: sub box
Not all subs are created equal. Some are better for larger enclosures while others are suited for smaller. What sub are you using and with how much power. Also, what kind of music will you primarily be listening to? Do you like punchy bass or low bellowing bass?
Old Mar 23, 2009 | 11:32 AM
2doorblazer's Avatar
2doorblazer is on a distinguished road
go to the wab site to whoever the maker of the sub is. an thay should have info about boxes for there subs an what is the best one for what u want
Old Mar 23, 2009 | 12:50 PM
txblazin's Avatar
txblazin is on a distinguished road
You need to know the specific air space required for your sub, to work most efficiently. Airspace can be the biggest differnce of a great sounding sub or not (regardless of $$). Most subs come with full specs or if your getting a used one check the manufacturers web site (usually there, as well). Then decide type of box you would like to build i.e., posrted, sealed, or bandpass.
Use the link below to assist with your physical build.
http://www.bcae1.com/spboxnew2.htm
Old Mar 23, 2009 | 05:33 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
you might also want to have this moved to the audio section
Canadian88
Dec 14, 2006 03:10 PM
rick465
Aug 25, 2006 09:37 PM
RdizzLe
Jul 19, 2006 12:33 PM
jagblazer01
Mar 15, 2006 07:58 PM
2001blazer
Jan 10, 2006 02:37 AM
