subs
Old Dec 27, 2005 | 09:09 PM
DS01blazer's Avatar
DS01blazer is an unknown quantity at this point
Default subs
i got som kickers and win i go offroding thay jump around what do i do to keep them still and from braking my LEDs.
Old Dec 27, 2005 | 11:37 PM
FatRyan's Avatar
FatRyan is an unknown quantity at this point
Default RE: subs
strap em/bolt em down
Old Dec 28, 2005 | 11:38 PM
2000ZR2's Avatar
2000ZR2 is an unknown quantity at this point
Default RE: subs
same thats all you can about do strap them bolt them or velctro and for the daring and cheap crappy look duct tape
Old Jan 1, 2006 | 09:43 PM
DS01blazer's Avatar
Default RE: subs
what about taking out the subs and drilling through the bottom of the box into the floor. And I was also wondering where is the best place to get blacked out taillights?
Old Jan 1, 2006 | 11:06 PM
FatRyan's Avatar
Default RE: subs
ORIGINAL: DS01blazer
you may be able to do that. of course it might be a real pain to do and if you dont do i the right way you run the risk of losing the seal, which could decrease output.
you can buy blackouts at pretty much and car shop, on ebay, and many online stores. shop around for the best price. or you could spend $5 and get a can of Night Shades spray tint and tint out all your lights like i did.
Old Jan 20, 2006 | 09:57 AM
85FSBSilverado's Avatar
85FSBSilverado is an unknown quantity at this point
Default RE: subs
If velcro will stick to your carpet well, you might try that, staple gun it to the bottom of your box.
-or-
You could bolt 4 L-brackets to your floor in the perfect position so the bolts are under the box and not seen. Then, you use some smaller screws and screw them into the side of the box. You could also use some T-nuts inside the box with some bolts that are the thickness of the board. Cover the end of the T-nut with a small piece of tape, and spread silicone caulking around the tape. Now air won't leak and you have a hard, well-mounted enclosure.
My Bronco and brother's Cavalier taillights:
Old Jan 21, 2006 | 08:47 PM
FatRyan's Avatar
Default RE: subs
ORIGINAL: 85FSBSilverado
nice
thrash902
Jan 28, 2010 06:58 PM
DS01blazer
Nov 8, 2005 12:06 AM
2001blazer
Nov 7, 2005 11:36 PM
Freekstile
Aug 19, 2005 04:40 PM
dobbist
May 22, 2005 04:48 AM
