Subs are popping and its not cool!!!
Old Apr 1, 2010 | 04:27 PM
TRILIOGYOFR's Avatar
TRILIOGYOFR is on a distinguished road
Ohk this is the deal chances are the channel (L) is bad if you want to verify instead of switching a whole bunch of stuff start simple check the subs on one channel (L) then the (R) which ever channel is having the problem mark then take a 2 female 1 male splitter hook it up to the good channel if that doesnt solve your problem then its at the head unit which could be as simple as a bad connection. Good luck.. Remember check every connection...
Old Apr 1, 2010 | 11:16 PM
bumpinBEATS95's Avatar
bumpinBEATS95 is on a distinguished road
i had the same problem, but i installed an output converter, and the popping quit
heres a link to the one i used
http://www.bestbuy.com/site/Scosche+...=1218106684939
its cheaper at walmart
Old Apr 1, 2010 | 11:51 PM
zedartwo's Avatar
Did you do all the unpluggin and fartin around while there stereo way playing. That could be a factor. Did you check the fuses? Could have blown a channel when the power wire was clipped.
Good Luck!
matt92
May 1, 2011 04:39 PM
adam7
Dec 13, 2010 12:39 AM
ohsofly
Sep 7, 2010 02:55 PM
RCars2
Aug 4, 2007 11:29 PM
blazinloud
May 1, 2006 03:32 PM
