Trying to pu a new system in a 02 blazer that came with a bose system
Old Dec 25, 2010 | 03:43 PM
liltittle62's Avatar
liltittle62 is on a distinguished road
Default Trying to pu a new system in a 02 blazer that came with a bose system
I have an 02 blazer with a Bose system and I am trying to install an aftermarket radio in it but when its all hooked up there is no sound, I keep hearing about an amp wire that needs to be powered up where can I finds this wire?
Thanks
Old Dec 25, 2010 | 04:17 PM
mr.vls's Avatar
See Attached Diag.
Attached Thumbnails Trying to pu a new system in a 02 blazer that came with a bose system-2009-02-12_232515_untitled.jpg
Old Dec 25, 2010 | 04:32 PM
ok thank you
Old Dec 25, 2010 | 06:47 PM
mr.vls's Avatar
Use the power ant. lead from your radio to power on the amp. Are you just replaceing the Head unit and using all the existing speakers? I have a bose unit as well and I would be curious to see how it all works out. Will you still have steering wheel control?
Old Dec 25, 2010 | 07:37 PM
mr.vls's Avatar
I did some internet searches to see what I could find out about integrating a new head unit with the bose system. For the best result I would consider utilizing the adapter listed below. It is a plug and play adapter. The bose amp uses speaker level input and not line level and the speakers are 1 Ohm and not 4 Ohm. The adapter provides the correct level input as well as providing a plug n play solution. My bose system works perfect at the moment, but you never know how long it will last, and if you want Ipod or other accessories then an aftermarket head unit would be a good way to go. Good luck on your install.
http://www.pac-audio.com/productDeta...&CategoryID=26
Old Dec 26, 2010 | 03:55 PM
ok I used the dark green wire that turns into a blue wire on the other side of the plug and connected it to the blue power antenna wire from the radio and it works and sounds alot better
unpredictable1
Oct 26, 2014 04:12 AM
CountryRed
Apr 30, 2010 08:12 PM
stevengrc
Feb 5, 2009 09:19 PM
89LX
Aug 17, 2007 04:12 PM
Blindthieves
Feb 4, 2007 12:35 AM
