Wiring power accessories
Old Aug 3, 2007 | 02:00 PM
nocluejimbo's Avatar
nocluejimbo is an unknown quantity at this point
Default Wiring power accessories
I have purchased a Harmon/Kardon Drive+Play to add iPod control to my the stereo on my 2002, and a 9-pin RCA auxiliary wiring harness to connect the audio. I have the control and screen hooked up, and will easily take care of the audio when the part arrives. I could wire the power to a cigarette lighter, but I would like it to turn off when the car turns off, so I need to wire it in.
My question now is how to wire in the power circuitry. The power cable has three wires, "battery," "ignition," and "ground." Where do I need to rout the wires and solder the connections?
Or, is there a way to have the power outlets only activate with the ignition?
Old Aug 3, 2007 | 07:49 PM
hillbillyinOhio's Avatar
Default RE: Wiring power accessories
just run a line up to the factory radio and there are your power, ground and switched power. Fuse the 12v constant though (yellow) that is exactly how I install them.(have done about 50 thus far!
Old Aug 3, 2007 | 08:43 PM
ORIGINAL: hillbillyinOhio
The 12V constant wire already has a fuse wired inline, so that is no problem. I found the color codes above. To what do I solder these connections? Just to the same connection the stereo's wires make to the harness?
Old Aug 3, 2007 | 09:35 PM
for 12v constant on your Factory radio, tag the orange at the radio. for the switched, you will have to tag the orange in the ignition switch bundle. ground is black
Old Aug 5, 2007 | 02:45 PM
I am installing the iPod interface's brain unit under the center console. Is it okay to wire the ground under one of the exposed bolts just beyond the carpet coverage beneath the armrest?
Old Aug 5, 2007 | 03:03 PM
should be fine. not much of a draw on that piece.
MuddBunny84
Dec 10, 2009 12:27 PM
phrankguy1
Jul 16, 2009 06:30 PM
a_tack
Dec 4, 2007 05:46 AM
BobTheBlazer
Apr 30, 2007 08:33 PM
mdhokenson
Jun 17, 2005 01:28 PM
