Wiring question
Old Jun 3, 2009 | 06:35 PM
classklown90's Avatar
classklown90 is on a distinguished road
Default Wiring question
Ok so a friend of mine told me how he wired some 12v accesories in his explorer, his method was stripping the end of the wire and wrapping that around the prongs of a fuse then pushing the fuse in its slot and grounding the ground wire. I told him about just tapping into the 12v accesory wire and wiringg to that but he said his method was easier.
So my question is, is his method easier and is it even safe??
Old Jun 3, 2009 | 11:10 PM
CDJr's Avatar
CDJr is on a distinguished road
Its pretty safe, but I wouldnt do it for anything that drew much amperage at all. Ive hard-wired radar detectors in a similar way but I laid the wire across the slot and forced it in with the fuse cuz it made a much tighter connection. Loose connection = Problems...thats also how many house fires start, cuz the loose connection basically acts like a miniature arc welder throwing sparks and heating up and eventually starting a fire or at least melting down plastic outlets, switches, etc.
Old Jun 3, 2009 | 11:30 PM
bandidolenny's Avatar
Is he putting the wire on the "load" side of the fuse so as to have circuit protection? If you are gonna wire up something that uses alot of amps then use a relay
Old Jun 4, 2009 | 04:16 PM
not sure bandidolenny. and thanks CDj
Old Jun 4, 2009 | 09:57 PM
skinaddiction's Avatar
skinaddiction is on a distinguished road
I am installing a two amp system in a friends 98 blazer with the factory head unit, what do I need for the pre-amps? What would they connect to?
phxjosh
Oct 30, 2013 10:03 AM
speedhead
Mar 16, 2012 06:54 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
Smoked
Jul 15, 2008 07:46 AM
Eden
Mar 30, 2008 03:45 AM
