1993 S15 jimmy "build"
#51
Should be much brighter than stock too. I know with less LED's and red's, mine were brighter. Next set will have more led's just because! Keep the pwm dry/sea;ed as well, which I'm sure you were going to already.
#52
While i was at upull, snatched a 3rd brake light off of a 94 blazer. Going to put it in the back behind the rear window up top (since I have the whale tail) I think it will look good. 4 LEDs were burnt out on the left side, 2 LED's in, so i just removed 6 from each side to even it out, still 32 on there.
Whats up city slicker!?
Told ya LeDs no good theres some burnt out!
#53
#54
I am going to mount the pwm in where the jack is. should be a perfect place for it, easy access also if I want to adjust the brightness of the running lights.
#55
Your led car gonba look like a jack-lantern going down the road with every other led burnt out! Hahaha!!!
#56
i'd rather look like a jack-lantern than joe dirt. stop talkin trash on peoples threads
#57
60 of them soldered up and good to go.
#58
Those had better be going in some tail lamps!!!!
#59
#60
