1995 Chevy Blazer project
Old Sep 28, 2017 | 08:24 PM
chevyriders's Avatar
Great project! It's going to be one super clean blazer.
Old Sep 29, 2017 | 05:40 PM
MountainDew's Avatar
MountainDew is on a distinguished road
Thanks, chevyriders!
This is going to be the wifes ride, she says she doest want any dirty parts on it She should have close to a brand new one when Im done.
Still trying to decide what color, we were thinking the factory Cherry Red, but Im trying to talk her into all black.
Old Sep 29, 2017 | 05:58 PM
Well a little update and its bad news. I found a crack in the transmission case.
When the transmission was in the old blazer it had a tiny leak from the transmission cooler lines, so when I took it apart I noticed both lines were plenty tight enough so I thought it was leaking around the brass adapter that threads into the transmission which the transmission cooler lines thread into the brass adapter. So I wanted to check to brass adapters to see if they were leaking, removed the bottom one no problem, when I went to remove the top one it was really tight, so I removed it put some sealer on it and when I went to tighten it I noticed something was wrong and a close inspection I could see a hairline crack. Check the pictures out. I went from having a good time to seeing red.
the crack is right above my fingernail, right on that casting seem.
So do I try to tig weld it? Im going to pass on tig welding it, I could but since I have another transmission Im going to pull all the new guts out of the cracked transmission and put those into the good case thats not cracked.
And check this out. Both transmissions are the same year 1995, suppose to be the same. Well it seems funny where the one transmission case is cracked it just so happens to be different between the two. Check out these pictures.
Cracked case
Not cracked, notice no casting web.
So now I get to take everything back apart and do it all over.
Old Oct 3, 2017 | 07:19 PM
Tajohns34's Avatar
At least you didn't put it in and start driving it and then notice it. That would have been much worse.
Old Oct 12, 2017 | 08:20 AM
Tajohns34 right on man. It sucked... but at the same time I'm happy it happened now.
Old Oct 12, 2017 | 08:29 AM
Im back where I was before I found the crack in the transmission and I got the fuel lines done, transmission lines done, power steering lines done, rear brake line done. Im almost ready to set the body back down on the frame.
Old fuel lines
New fuel lines, nylon with quick connects.
Switched all fuel lines to nylon, no more RUST
Used copper nickle for the vent line.
Stainless steel transmission lines from Summit Racing. Notice the nuts are not stainless. Why would they put regular nuts on a stainless line, makes no sense to me.
Old Oct 14, 2017 | 02:23 AM
Very nice build.
I'd love to have your place. No shuttling of parts and cars between places where I have a lift that I can use. Nice and clean work. Love it.
Old Oct 15, 2017 | 09:12 AM
Thanks error_401 In my younger years I had to work just like you said, moving parts around - cars. I use to work in the gravel driveway on ramps. It wasnt much fun especially when you get all set up and it starts to rain
Old Oct 15, 2017 | 09:21 AM
Well another pissed off moment for me. So I got to put the body on the frame so this means once again I could lift the frame body all at once on the lift. So I have it up in the air having a look around and son of a mother trucker. THE FRAME IS CRACKED
and on the other side of the bracket
So today I get to remove the front dif and weld up some cracks. I have seen a lot of blazers with the frame cracked around the front dif mounts but man o man how did I miss this crack 50 hours ago.
Old Oct 17, 2017 | 09:10 PM
95teal4x4's Avatar
95teal4x4 is on a distinguished road
Just read this build. I would love to do a body off restoration of my blazer like you are doing. Maybe someday. That blazer will be better than brand new from all the work and parts you are doing to it. Should make the wife pretty happy lol. I'll be watching this build for updates. Keep up the good work!!
