2001 LS off road build
Old Jul 31, 2021 | 04:49 PM
BritishColumbiafishing's Avatar
BritishColumbiafishing is on a distinguished road
Oh for the arm and pivot? Yes, they are for a 1-ton chevy truck and are being repurposed for a Blazer with the help of the bracket.
Idler Arm Pivot #K6723 is the pivot the bracket you speak of?
Old Jul 31, 2021 | 09:54 PM
Yes I belive so. I'm going by whatever they listed at the Outfitter Design website.
Old Jul 31, 2021 | 10:00 PM
I'll order t and install it by mid next week. I'll let you know if it fits
Old Jul 31, 2021 | 10:13 PM
Hess13x's Avatar
Here is the bracket you need to install so those parts will work.
https://www.outfitterdesign.com/1-to...m-bracket.html
Old Sep 4, 2021 | 03:45 PM
Wastedwages01's Avatar
Wastedwages01 is on a distinguished road
Default .
Quilt over?? Coil over, not sure if it can he done, anyway I have a 4 door ls, not the best for off roading unless you change a few things, i needed to get a custome front shaft as the zr2 blazers have a longer one, the rough country shocks are garbage ×10, I have gone through 4 pairs in 3 years. As i am now changing to bilstine 1500 if i can find some that fit!, the steering box is (sloppy) i added a rough country steering stabilizer, the leaf springs are very long and can be worn down very easily if you load up. I'd recommend adding 2 more stacks. Also fitting 32inch tire you will definitely need ofset rims and to cut a bit of rear bumper.. do your fuel pump befor any of this stuff.
The truck is very capable off road if you know what to do
It can be done a member on here used a off-brand set from Amazon drilling out the bolt holes but it was for stock ride height. I think I've decided to ditch that idea and just go with the 6-in suspension lift.
Old Sep 4, 2021 | 07:20 PM
I got coil overs for the rear of my moms jimmy... I should find those for the front... forgot about them!!! I think it was for a vw bug....
Old Sep 4, 2021 | 07:51 PM
if your going to do a 6 inch lift and actually use it for wheeling I'd recommend a double cardan driveshaft to save your truck from disaster. That is if your truck is actually going to flex
Old Sep 4, 2021 | 08:45 PM
empi 00-9570-8 is the part number and yea for a older VW
Old Sep 4, 2021 | 08:49 PM
ok thanks I'll check in to that, Yea I don't cut it any slack lol. Do you have any recommendations for the best spider for this type of use, mine is starting to leak and needs replaced.
Old Sep 4, 2021 | 08:52 PM
I went to a driveline shop and got a front prop shaft done they did all the work for me as it was a custome shaft. I did some damage with the stock 1 with only a 3 inch lift
