2004 5.3L 2004 2dr Blazer Ls
Old Mar 20, 2022 | 02:32 AM
Life is a Enigma's Avatar
Life is a Enigma is on a distinguished road
Started lapping in the valves today in my 243 heads. I also replace valve stem seals and added the GM performance valve springs that go with the LS6 cam.
before
After
Old Apr 6, 2022 | 08:22 PM
I weighted my Blazer today. with the 4.3 & 1/2 a tank of fuel.
Old Apr 10, 2022 | 05:20 PM
The drive by wire gas pedal is done. I modified the one that came from the 03 Yukon when I bought the 5.3L. I used the original S10 pedal and merged it with the Yukon.
Test fit.
Old Apr 15, 2022 | 11:30 PM
My block is back from the machine shop. I painted it GM satin black and I put the LS6 cam in with Melling timing chain guide.
Corvette LS6 2002-04 12565308
Old Apr 16, 2022 | 09:46 PM
Crank is in and torqued and put new barbell in oil gallery. Tomorrow off to the fun task of gapping all 32 rings and installing the Pistons.
Old Apr 18, 2022 | 03:26 AM
Old Apr 18, 2022 | 08:01 AM
Nice! She's coming along... looking foward to seeing it done!
Old Apr 18, 2022 | 12:04 PM
Me 2.
Old Apr 18, 2022 | 09:16 PM
Pistons and rings are gapped for nitrous rods torqued with ARP bolts. I checked the Piston to deck clearance it changed my compression ratio to 10.6.1 I was shooting for 10.5.1 but I guess it's better to have a little over than under. Oil pumps in pickup is installed with ict billet hold down where it has two bolts.
Old Apr 19, 2022 | 12:30 AM
Are you planning on racing it? Drag or track? Or just want power under the hood?
