2004 5.3L 2004 2dr Blazer Ls
Old Apr 19, 2022 | 03:11 AM
  #21
Life is a Enigma's Avatar
Life is a Enigma is on a distinguished road
Originally Posted by DonL
Are you planning on racing it? Drag or track? Or just want power under the hood?
It's going to be a daily driver but occasional track and next year going to take it on race week have a little fun.
Old Apr 20, 2022 | 02:26 AM
  #22
Ok
Old Apr 22, 2022 | 12:29 AM
  #23
I painted my valve covers with 2 coats Wrinkle Plus Black and with 2 coats semi-gloss clear coat. Only thing I'm missing is the PCV grommet for some reason it didn't come in the gasket overhaul kit I purchased 😕. Working on the valley covered next it's also going to be Wrinkle Plus Black with clear coat. The valve covers were baked for 3 hours at 280° to seal the paint nice and tight to the valve cover.
Old Apr 23, 2022 | 02:52 AM
  #24
I install the harmonic balancer and water pump and I'm just test fitting the AC pump and exhaust manifolds. Did running to one issue on the driver side of the oil pan the fourth bolt from the front was not drilled on my block. Had to drill and tap. Anybody else run across this issue with the GM muscle oil pan? You can see it in the picture where the bolt is missing from the oil pan.
Old Apr 23, 2022 | 10:04 PM
  #25
Did a pre-start compression test it was not too bad.
#1-208
#2-199
#3-200
#4-200
#5-201
#6-199
#7-209
#8-199
Old Apr 23, 2022 | 11:30 PM
  #26
Looking good... those are some nice even numbers across the board... waitting for the first ignition!!
Old Apr 24, 2022 | 02:11 AM
  #27
Installed new flex plate and torqued also change fuel rails to non-return style decided to go with the Corvette fuel filter with the built-in return.
Old Apr 24, 2022 | 02:17 AM
  #28
Me too. I wanted to get pre-start compression test number then after first heat cycle then after first week of driving that way I have a baseline for compression down the road.
Old Apr 25, 2022 | 05:19 PM
  #29
Fix that ugly hole in the side of the engine cover.
Old Apr 26, 2022 | 12:34 PM
  #30
Nice! Did you plastic weld it in? What material did you use?
