74 k5 blazer build
Old May 23, 2011 | 01:23 AM
quest97223's Avatar
quest97223 is on a distinguished road
Default 74 k5 blazer project build
This project has been awhile in the making. I have never posted anything before so I figured why not start. So first thing is, I traded a 93' jeep grand cherokee for my beastly 74. It was kinda beat up and ran ....sort of. It would die every time you came to a stop. I decided I wanted to go with red and black instead of the blue color. First thing I did was gut the interior. I tore everything out, dash and all. I then patched, sanded, grinded, and cleaned the floors. it was tough. My next step was painting the floors with rustoleum then covering that with bed liner. I then sanded and painted the metal parts of the dashl and patched the dash pad with fiberglass then painted it black. That was very very tough. I do not recomend patching the dash pad. It was trial and error and took forever to get the cracks not to show. I then installed a cup holder thing in the middle and painted the seat brackets. I put in a new 4x4 shift **** and boot. Put on a new steering wheel, turn signal **** and shifter. I painted the column. Painted the instrument panel and put on white gauges. I also installed red bulbs behind for a red glow. The column shifter was a pain. I had to grind the new chrome one to fit. I also cut the pedals which was actually pretty hard cause I had to use a jig saw through that thick metal. I took off the doors and painted the doors and panels. I cut the door locks so they did not stick so high up and I bought a rear floor mat. I now am in th process of tearing apart the engine to begine the rebuild. Its a 68 327 with 2.02 camel humpers. Any suggestions?
Attached Thumbnails 74 k5 blazer build-33632_1356034155789_1679523392_630250_12864_n.jpg   74 k5 blazer build-33661_1358824625549_1679523392_636806_2269991_n.jpg   74 k5 blazer build-33700_1356034595800_1679523392_630255_7370054_n.jpg   74 k5 blazer build-33712_1356033715778_1679523392_630246_3824099_n.jpg   74 k5 blazer build-33718_1358824025534_1679523392_636802_6563240_n.jpg
74 k5 blazer build-33883_1356035995835_1679523392_630267_4500775_n.jpg   74 k5 blazer build-33909_1356035595825_1679523392_630264_6178461_n.jpg   74 k5 blazer build-34417_1356036075837_1679523392_630268_5847416_n.jpg   74 k5 blazer build-34424_1356036235841_1679523392_630269_4271723_n.jpg   74 k5 blazer build-34688_1356035395820_1679523392_630262_4155215_n.jpg
Old May 23, 2011 | 09:34 AM
quest97223's Avatar
Default More pictures
here are more pictures of the k5
Attached Thumbnails 74 k5 blazer build-34719_1356035315818_1679523392_630261_4676160_n.jpg   74 k5 blazer build-34731_1358824225539_1679523392_636804_8077863_n.jpg   74 k5 blazer build-40756_1356035715828_1679523392_630265_580178_n.jpg   74 k5 blazer build-40879_1356033875782_1679523392_630247_120747_n.jpg   74 k5 blazer build-40879_1356035915833_1679523392_630266_2557970_n.jpg
74 k5 blazer build-40903_1356033955784_1679523392_630248_4180348_n.jpg   74 k5 blazer build-44208_1358824705551_1679523392_636807_7685538_n.jpg   74 k5 blazer build-44887_1358824425544_1679523392_636805_7733504_n.jpg   74 k5 blazer build-46346_1356034715803_1679523392_630256_4538259_n.jpg   74 k5 blazer build-46974_1356035195815_1679523392_630260_2313061_n.jpg
Old May 23, 2011 | 09:39 AM
quest97223's Avatar
Default even more pictures
here are even more pictures of the project
Attached Thumbnails 74 k5 blazer build-47067_1356035035811_1679523392_630259_262176_n.jpg   74 k5 blazer build-58210_1329884942075_1679523392_581225_4916072_n.jpg   74 k5 blazer build-62108_1356034915808_1679523392_630258_1500987_n.jpg   74 k5 blazer build-62344_1356034835806_1679523392_630257_7022907_n.jpg   74 k5 blazer build-62361_1356034035786_1679523392_630249_6165258_n.jpg
74 k5 blazer build-62447_1356034235791_1679523392_630251_6871647_n.jpg   74 k5 blazer build-62550_1356033395770_1679523392_630244_7272690_n.jpg   74 k5 blazer build-62723_1356033275767_1679523392_630243_317000_n.jpg   74 k5 blazer build-62791_1356033595775_1679523392_630245_7322602_n.jpg   74 k5 blazer build-62804_1356034435796_1679523392_630253_2409392_n.jpg
74 k5 blazer build-62860_1356034355794_1679523392_630252_4552760_n.jpg   74 k5 blazer build-63344_1356034515798_1679523392_630254_368360_n.jpg
Old May 23, 2011 | 09:43 AM
quest97223's Avatar
Default still more pictures
yep still more pictures of the project
Attached Thumbnails 74 k5 blazer build-162650_1448762833948_1679523392_787709_4281177_n.jpg   74 k5 blazer build-163085_1448762073929_1679523392_787706_2940691_n.jpg   74 k5 blazer build-166824_1448761673919_1679523392_787704_1422249_n.jpg   74 k5 blazer build-167119_1448762433938_1679523392_787707_5128710_n.jpg   74 k5 blazer build-168141_1448761273909_1679523392_787703_1529324_n.jpg
74 k5 blazer build-168552_1448761873924_1679523392_787705_8193792_n.jpg   74 k5 blazer build-208456_1565888842025_1679523392_958305_1376321_n.jpg   74 k5 blazer build-208474_1565881401839_1679523392_958299_3376495_n.jpg   74 k5 blazer build-215683_1565880241810_1679523392_958298_4596877_n.jpg   74 k5 blazer build-215810_1565889322037_1679523392_958306_4938533_n.jpg
74 k5 blazer build-215988_1565884681921_1679523392_958303_5012714_n.jpg   74 k5 blazer build-216788_1565884321912_1679523392_958302_3499584_n.jpg
Old May 23, 2011 | 09:44 AM
quest97223's Avatar
Default the last set of pictures
last set of pictures so far.
Old May 23, 2011 | 10:39 PM
79blaze's Avatar
79blaze is on a distinguished road
Great job on the interior man. I am starting the same process. What kind of bedliner did you use? I have heard the raptor stuff is pretty descent.
Old May 24, 2011 | 07:41 PM
quest97223's Avatar
I used the herculiner. It was actually in the pile of junk inside the vehicle. Two cans of it, so I was pretty excited! It was ok though, It came out kinda bumpy so I think I am going to have to put vinyl flooring over that.
Blaze1Chef
Mar 7, 2021 10:44 AM
ZachC540
Nov 26, 2016 01:44 PM
JS_blazer
Mar 21, 2010 07:17 PM
91 Streeter
Jan 26, 2007 11:10 PM
