85 K5 Blazer First project truck
Old Sep 4, 2013 | 08:32 PM
Rfunder12's Avatar
Rfunder12 is on a distinguished road
Default 85 K5 Blazer First project truck
Would like to get some Ideas on where to start on this truck really .... the truck is for general offroading without serious mudbogging/rockclimbin
Right now it has a 350SB
T350 Trans
4.56 Front
4.10 Back
New Carb
6 inch Lift ( All parts worn out mostly )
Attached Thumbnails 85 K5 Blazer First project truck-1234992_4531189857115_1545299998_n.jpg
Old Sep 7, 2013 | 02:13 PM
Coddrick's Avatar
Coddrick is on a distinguished road
Hi Rfunder,
First off, nice looking rig, but it looks like you already have a good wheeling truck, is there anything it doesn't have that you wish it did? Knowing that might be a good place to start.
Second thing to consider is; does it need any attention currently, I spent the first year and half of my build on just rust removal. How is the engine, tranny, and t-case? Anything leaking, running poorly, or just not meeting your needs?
After that it's down to customization, paint job, under-coating, bed lining, sound system.
I started my build by, knowing what I wanted, what I needed, and taking care of the most pressing matters first. I hope this helps, just trying to give you some tips I learned along the way. Good luck!
Old Sep 7, 2013 | 03:56 PM
abig84's Avatar
get your gear ratios matching first of all. put that thing in 4wd now and everything is going to bind and make all sorts of wonderful noises unless you are in slippery stuff
Old Sep 7, 2013 | 08:16 PM
Rfunder12's Avatar
Tbh this is my first tuck that I actuly like and want to spend the time and money on.... And today was the first day I took it out and It did well It does not like to stay in 4wd It will stay intill i start to flex and move the body at all really and it pops out of 4wd Did fine in smaller water but I didnt try anything to crazy still looking at tires and dono what to get thats good for road and Offroad.
And my goal in the long run is to have something I can drive everyday and still go off on the trails with my buddys ...moneys not a issue
Engine is in perfect running condition just not alot of power for this truck
T case not really sure atm All i know is its a 208
Tranny is in good shape only 8k miles on it
Dont know alot about the history on this truck only that who ever built it did not know what they where doing was a mess when i got it
and very very very min rust the only amout of rust is on the driver and pass floor boards
Attached Thumbnails 85 K5 Blazer First project truck-1234097_4575186717009_795568518_n.jpg
Old Sep 9, 2013 | 07:53 AM
Crackers's Avatar
Crackers is on a distinguished road
X2. Thats probably why it pops out of 4wd. Can (read as: will eventually) break u-joints, bend driveshaft(s). Not to mention destroy your transfer case and really diminish the effectiveness of 4wd since the tires will no longer turn at the same speed.
Regardless, I really like these older style Blazers, this one looks really clean.
97CountryJukeboxLt
Feb 24, 2011 10:07 AM
ZigZaggle
Aug 5, 2010 02:19 AM
Meganutter
May 13, 2010 11:22 AM
Biohazed
Mar 24, 2010 05:35 PM
loomdog32
Jan 9, 2010 07:01 PM
