86 blazer with 54" swampers
Man I hope you are throwing 1ton axles under this truck, at the very least... Or better yet, 2.5ton Rockwells...
If the owner is going to use the truck as a true offroad ride, the real tire size limit of the stock axles is around 33"-36" depending on the level of offroading... The stock axles will not hold up to 54's.
i knew it had to be a K5-there's no way anyone would want to do that to a '86 "S" Blazer. now if it were a '91-'94 "S" series Jimmy.................hahahahaha!
i'm sure he's gonna use the Rockwell's. be the smart thing to do.
I believe he will need more than 18" of lift to fit these if its uncut ........If he is runnin stock wheelbase this thing will be a death trap on handling ....... still interested in seein this....
lol..this is turning into another "Will it fit" thread. Hey, could I fit 54" swampers on my Blazer do you think? I have stock everything. I was thinking of cranking the tbars a bit to make them fit though . I feel like making a video for the forum with the same guys from "Will it blend!?" hahaha
Anyway, the OP better not disappoint. We better see pics today or at the very latest tomorrow.
This build will not see off road, it still has 1/2 ton running gear. It will be used for show and advertisement for his business. I will be building the new drive lines and it will be a true 4WD but no mudding with this truck.
Subscribed. Pics now.
This will still be interesting to see. Those 10-bolt axles are going to look like tooth picks under that truck!
You are going to have to do some fab work on the steering with that much tire and that much lift. I suggest you start off with doing a cross over steering setup instead of the factory arrangement.
With tires this large, would not a monster truck frame be an easier way to go? Then just perch the body on top of it?
Just my
Just my
What is a 'monster truck frame'? Thats not somthing you just go and buy..... I think you mean a custom tube chassis. If hes just building a mall crawler with it then no it wouldnt be easier...... And the way it sounds , by him lifting it to fit them , thats what hes doing. If he lifted a trail rig that high to fit 54's it would turn over if you drove over a coke can on one side........ I would get a sawzall and go to town on the fenders . Prob have to run hydro steering , the drag link angle is gonna be insane with the amount of lift its gonna take to fit these without cutting the fenders......
A super lifted, pavement only mall crawler! This I gotta see!
We used to double frame them when going so large. Wait till you see how many hot dog sized wheel weights it takes to get it to roll smooth!
