96 4 door 4x4 Every Day Driver
#51
I am not sure that I read that right, are you running with no Catalytic converter?
#52
Yep
Good to hear from you
#53
That might cause the computer to run your engine too lean and eat you piston rings.
#54
I don't think so. Not just removed. A special spacer called a "Bong" to work with the computer; so as to NOT mess up the mixture.
The "honeymoon" is over though. Sputtering and puttering again an eng. lit is on too ..........
#55
Cooling system update
Finally popped the dash open to replace the climate control panel. The old one was sending air to all the wrong places - all the time. I couldn't even feel the A/C set on Max and temp to blue bottom.
Good news first:
The heater core opened up and the "floor" setting worked great.
Bad news next: I cannot tell if the other setting are 100% and the A/C "on" doesn't create "cold." I am thinkin' that may be a fuse or "Monster Fuse" some where because the A/C clutch does not engage.
Good news first:
#56
"Dome Override" - still a mystery
While I got it all open and apart; I was hoping to solve the mystery behind "Dome Override." the 95 & 96's were wired differently than the newer ones (or older ones, for that matter). I have a '99 switch panel complete with wires) but I can find no direct correlation in wire colors to the "Courtesy" lights. Or even the "door open" sensor "on/off." If I could just get my hands on that, I could use the unused "fog lamp" switch and close that case. There are a hundred ways to accidentally kill your battery. I think an open door is at #1. I like to camp. We all like to leave the doors open when accessing and using our gear.
I found the mini-fuse OK but that also kills the Rear window latch. None of my crew are gonna insert the fuse just long enough to pop the rear window,
I just gotta find a way to put a switch on "Dome Override."
#57
A/C Clutch not engaging
Good news first:
Good news first:
Now to find out why the controls don't turn it on. He thinks it may be a relay but Google kept showing us diagrams of "other than '96 wiring." The mini-fuses are all OK. I came back here and tried a search for: A/C Clutch not engaging, A/C Clutch not working, A/C not working and only got hits when I said "A/C" . That gave me a million posts that may have A/C somewhere in the thread. Anybody have any advice that maybe useful top the 95/96?
#58
I need to revisit all the places I have been pulling on and playing with my connectors. The wipers are unreliable and even the squirter switch works when it wants to. I think I knocked something loose somewhere. It's more than the A/C clutch now.
July in South FL is no place to drive without A/C
#59
Change the a/c dash controls. Mine did the same thing.
#60
Thank you.
I picked one up at the yard about 9 months ago. Just waited until I took the dash apart to change out the stereo. The speed control wheel was shot. I replaced it with the stereo 2 months ago. It could be defective. Looks new. 1996 was a long time ago though. My Alternator has been whining loudly for quite awhile. I'm thinkin' it may be a "low power" thing too.
I have been searching for a DR44G or AD244 forever. I cannot say that I even know what either looks like. Today I just broke down and pulled a really big one from a 99 Tahoe with front & rear A/C at the yard. The Tahoe had two wires on the plug. I hope I got that right.
If so, my "Big 3 will be complete. If it doesn't fix the A/C clutch - back to square one.
