99 4 door blazer
Old Sep 18, 2018 | 06:59 PM
  #101
Worked on the flares again tonight, got A LOT more accomplished tonight then over the last few days. So happy I grabbed the plug in cutter. Plus at the end of the night, I noticed that the saw blade was on backwards
Old Sep 18, 2018 | 07:06 PM
  #102
Tomorrow I will hopefully remember the strips from work, I'll be using them to make the brackets necessary to hold the flares. After that, I will be adding some spray foam to fill in the voids, bondo to cover the exposed areas, and then it will be prep for paint and install. I keep telling the wife that they won't be on before winter, but the pace I'm moving now, it might be, especially if I take it to work to sand and paint.
Old Sep 18, 2018 | 07:52 PM
  #103
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
No, I'm clear across the country in SE Washington.
Old Sep 20, 2018 | 06:04 PM
  #104
Grabbed the galvanized steel strips from work today, was able to mock up some brackets for the flares. I have the drivers side complete, might work on the passenger side tomorrow, weather pending. Cutting out bottom bracket. Drilling hole in top one and adding a bolt.
Two brackets at the top. Riveting to fender lip.
Fender bolt on side bracket, screw on the bottom where the c clamp is.
Bracket locations, bent them by hand, sturdy enough they wont moved onve riveted to the door. Will also spray foam void.
Rear flare will be riveted to factory fender lip. It lines up nicely after the door is cut out. There are no brackers needed for this one.
Old Sep 20, 2018 | 06:12 PM
  #105
G0LFADD1CT's Avatar
I'm not usually a big fan of fender flairs but those are going to look very nice.
Old Sep 20, 2018 | 07:15 PM
  #106
Thanks. Really trying to make it look stock. So taking the time to make it right.
Old Sep 20, 2018 | 10:02 PM
  #107
N. Jensen's Avatar
Yeah, wow, they have come out brilliantly. Very nice, Don. I'm now on the lookout for some..
Old Sep 22, 2018 | 07:19 PM
  #108
Front driver is ready for install... drilling the hole for the bumper flare in the morning. Mounted and trimmed the brackets on the front. Used gorilla duct tape and gorilla double sided tape for up to 30 lbs, and I also riveted the bracket to the fender.
There will be a rivet above, and below the vise grip. As well as the bolt i will be putting through the factroy bracket on the bumper flare.
Old Sep 23, 2018 | 06:19 PM
  #109
Front fenders are done. Rear are all trimmed up and ready for foam and bondo.
Old Sep 23, 2018 | 06:23 PM
  #110
Progress on the rear.
