99 4 door blazer
Old Aug 6, 2021 | 08:48 PM
  #591
eshaw's Avatar
It's nice that you got the cast iron diff up front. That will give you a little added insurance.
Old Aug 9, 2021 | 05:10 PM
  #592
Definitely!!
So the mechanic ran into something.
When the trucks front front gets weight lifted from it, the cv axles start to bind from the angle. Which happened before when my front end was torsioned all the way. So I mentioned about backing it off a little, which he did, but still happened, so he wants to look into a little more tomorrow. I really don't mind because his price is easily the best I'll ever find, and he does a little extra at no charge, so it's above and beyond reasonable...
Will update all threads necessary when I receive the blazer
Old Aug 9, 2021 | 05:15 PM
  #593
Hadyss's Avatar
I’m gonna add onto the rough country upper arms the stoppers so limit how much it can drop
Old Aug 10, 2021 | 09:04 PM
  #594
So the angle of the diff was/ is off...
Not sure what was causing the sound bsound...
Took her home, and the 3.72 gears are already telling me they are there! Get all 6 cylinders back,and I'll be laughing!!!
All that room!!!
Old Aug 10, 2021 | 09:21 PM
  #595
Hadyss's Avatar
I love my 3.73 gearing I’m running 33s now and it’s not that bad with the 3.73. Now my question is what u-joint did u use for the zr2 rear diff and where can I get it
Old Aug 10, 2021 | 10:37 PM
  #596
3.73 gears on 33 inch tires? I'd think you'd want 4.11 gears. Also, didn't ZR2s only come with 4.11s?
My question is prompted by how with larger tires, the effective or equivalent gear ratio is reduced. https://tiresize.com/gear-ratio-calculator/
For my rig, with my 30s, my effective gear ratio dropped from 3.73:1 to 3.48:1 (when compared to the stock 235/70 R15s).
Old Aug 10, 2021 | 11:00 PM
  #597
Hadyss's Avatar
Yes the 33s would drop me to 3.26:1 but it doesn’t feel that bad and still seems to have some power. All the zr2 over ever seen have the 3.73:1 with 31s stock
Old Aug 10, 2021 | 11:03 PM
  #598
Hadyss's Avatar
What I don’t understand is if I put the same 33s on a zr2 it’s effective gearing would be 3.5:1 since they are stock 3.73:1 with 31s stock. That’s the only reason I didn’t think the 33s would be that bad
Old Aug 11, 2021 | 06:09 AM
  #599
I lucked out when I found this axle and it came with the longer yoke. If you look at my axle swap thread, you can see it on the axle when it's not installed.
I got my axle from a zr2 pickup. That might be where to look... I'll get a picture of it today at work sometime
Old Aug 11, 2021 | 06:52 AM
  #600
[QUOTE=christine_208;736161]3.73 gears on 33 inch tires? I'd think you'd want 4.11 gears. Also, didn't ZR2s only come with 4.11s?........
I think in one of the axle threads on here not sure if it was put on mine or another, that the 2wd 5 speed came with a 4.11 gear ratio option but none of the other models did...
