Baby Semi Build
Old Sep 2, 2012 | 04:30 PM
  #251
richphotos's Avatar
Damn man, I'm impressed, Get a boot to go around that opening, FTW. Real nice job
Old Sep 3, 2012 | 04:59 PM
  #252
xgiovannix12's Avatar
I took the truck for a ride and at the gas station I had a nice puddle of tranny fluid under my truck...
Well it leaked from the transfer case switch... IM just about done with this switch bull ****. Im hooking my front diffy to a switch with an vac solenoid and thats about it.
While fixing the leak I did a fluid change on the tcase and took it for a test drive... No leaks so far
This is how I fixed the leak for now...
I need to replace the part I used rtv on.
On a side note I pulled the lines into the engine bay for the vac solenoid and hooked them together to try the 4wd. Now I have a bolt in the vac line portion so it dont leak and cause the truck to run bad.
Old Sep 4, 2012 | 01:07 PM
  #253
rexmburns's Avatar
Super Moderator
Gio did you see that okiedoak responded to you on your wanted ad? I know him personally and hes a great guy hope he can help you out!!
Old Sep 4, 2012 | 01:32 PM
  #254
Yea We are currently working out a deal.
Went food shopping today blazer ran Great. The connector on the vac switch sweated a little but No leaks...
Im happy till I get the parts to fix it.
Old Sep 4, 2012 | 01:40 PM
  #255
richphotos's Avatar
Good stuff brosky!
Old Sep 5, 2012 | 05:01 PM
  #256
SO last night I started making the Hole cover / Shift boot... I made a lock ring out of diamond plate.
I had some old leather sitting around but then I decided it was to hard to make one with leather because of the Positions on the tcase.
SO I got some rubber and cut a nice slim hole in the center.
I messed up on screw placement but it still looks good... I like it. Just hope it works just as well as I thought.
Old Sep 5, 2012 | 07:28 PM
  #257
Installed the shift boot and it works really well . There is finger prints on it since it was not 100 % dry but it was so worth it....
Ill repaint it tomorrow.
Old Sep 5, 2012 | 07:35 PM
  #258
richphotos's Avatar
Nice job!
Old Sep 5, 2012 | 09:46 PM
  #259
So i repainted it tonight
So humid out hope it settles ok.
Old Sep 6, 2012 | 12:33 AM
  #260
Thogert's Avatar
That's awesome. See I knew you could think of something for cheap/free.
