Black 4 door jimmy build
Old Jun 27, 2021 | 12:21 PM
  #21
Jimmybuild's Avatar
Jimmybuild is on a distinguished road
A bit of an update on my 1996 jimmy. Installed a double din stereo today. Looks and sounds great. Did a write up on it in the audio section. Whent out to a wreckers yesterday and picked up a full floor shift center console with shifer and a used brake booster (nasty to remove but mine is leaking) all for $20 . Not going to complain. So that will be next weekend project. Also found a set of 17" alloy wheels from a camaro that are going to go in for soda blasting. Lots of fun coming up for my truck. Will update as i go.
Old Oct 22, 2021 | 09:58 PM
  #22
bikerider's Avatar
bikerider is on a distinguished road
Originally Posted by Jimmybuild
installed led headlight bulbs.....what a difference.
It really is. I did this recently too and it is so much better on dark rainy nights.
Old Nov 19, 2021 | 01:03 PM
  #23
boudreaux55's Avatar
I like the interior panels very much.
U said they are 1 offs. Who did em 4 u
I used 2 door og rear plastic panels on my build, long story on a 97 4x4
Had to make the rest using abs sheets and a heat gun
Same w/walls. But an escalade headliner worked well. Including rear a/c. Almost done...
Old Nov 19, 2021 | 01:05 PM
  #24
Im liking the new led lights too
Old Nov 24, 2021 | 08:39 AM
  #25
surreybrad's Avatar
surreybrad will become famous soon enough
Default 2 ZR2s
I have a 2005 Jimmy Highrider ZR2 and a 2000 Blazer ZR2 that are in stages of restoration. Interior is a difficult issue although the Jimmy has the aftermarket faux carbon fibre bezels and door panel inserts. Your interior upgrades are really nice. May I ask did you do them and what did you use?
Old Nov 24, 2021 | 09:40 AM
  #26
I used the 95 2dr blazer rear panels, cutting the top roll over part and added abs plastic, welded too existing length to roll up the wall and carpet to cover.
in the very back, i made pieces using 1/8th inch abs plastic to cover the rear a/c of a 2000 escalade. Also used that same headliner for all the overhead vents, etc. A friend made a plenum to go inside the wall to transfer the ac.
the fold down seats worked well in the back too.. i cut the hardwood floor out of 54 dodge and used blazer rear floor, welded in.
Measuring the dodge and what to keep
Fitting the firewall to cab byshings with dash clearances at "a" post
Sandblasting and then add rear section of 4dr blazer flooring
Old Nov 24, 2021 | 09:45 AM
  #27
100 percent photos to come
Ive cleaned up where they join with a small rectangular curved piece w/carpet to hold both in place
Both rear pieces come out, passenger side has rear ac, drivers side hides jack, tire tools, and fuel neck
Old Nov 24, 2021 | 10:31 AM
  #28
Old Dec 10, 2021 | 03:10 PM
  #29
Did you ever tackle to fender flares?
DonL
Mar 30, 2026 02:48 PM
Red 96'
Feb 15, 2014 06:32 PM
97Beater4WD
Mar 13, 2012 04:58 PM
97Beater4WD
Lifting Tech
Feb 5, 2012 03:07 AM
Red 96'
Aug 23, 2010 04:27 PM
