Chevyriders Minnie Jimmy project (Return of the Minnie Jimmy)
#72
Thanks guys.
so lately ive done upper and lower balljoints and cv axles on both sides, and also replaced the brake line that runs from the front to the back, because that went bad on me.
I also started installing a touchscreen radio. Got it in and working, but still have to mess with the bezel to get it fitting right. If I can't use the one I have from the single din radio I'll probably just design and 3d print myself a custom one.
this weekend I'll probably mess with it a little more. I also gotta install a new multifunction switch i got becsuse my hazard switch is broken
#74
It's just a dual.. nothing fancy just does Bluetooth and has input for a back up camera. A buddy of mine had it laying around and gave it to me, so I'm definitely not complaining for the price of free.99
#75
Well I made it work for the most part with the dash kit I have. just going to have to print a couple small filler panels for either side of the unit. terrible pic, but you can kinda see what im talking about
check engine light is on for rear o2 sensor. says no communication, so ill have to make sure the wires are good and its plugged in properly( i removed it when i did the y pipe) if its not good ill switch to a known good one i have from by blazer
