Engine Swap 4.3L V6 to 4.8L V8
I have a 97 LS 4X4 i've bin reading a lot on the forums about increasing HP in the 4.3L motors and it seems that unless you have alot of money there is not much that can be done cheeply. I've also seen alot about 350 swaps but i don't really want to go with a big motor, i've bin looking into the 4.8L motor offered in the newer chevy tahoe and yukon's. it's the smallest V8 GM makes with 275 - 295 HP stock i think it will be perfect for my 97 blazer increasing HP with not that much of a weight increase so my question is can anyone tell me if the 4.8L vortec will bolt right in or not? i know the motor mounts will probably need to be re-worked, i need the wire harness, and the ECM but will it bolt to the 4L60E tranny?
this is just an idea for now
any info would be greatly appreciated Thanks in advance
the reason I want the 4.8L is because i want the extra 100 or so HP and 50 + torque with as little MPG increase as possible the 4.3L and 4.8L are very close. not to to sure what the weight difference is between the 4.3L and 4.8L tho but i don't think the 4.8L is that much more heavier and i found a 4.8L all accessories, harnes, ECM for $600
I realize this doesn't really answer your question, but something to consider.
The LM4 and L33 are both aluminum versions of the 5.3L LSx style engine. These engines should be about 20 pounds lighter than a 4.3L.
What did those motors come in?
LM4 applications:
LM4 applications:
- 2003-04 Chevrolet TrailBlazer EXT
- 2003-04 Isuzu Ascender
- 2004 GMC Envoy XL
- 2004 Chevrolet SSR
- 2004 Buick Rainier
L33 applications:
- 2005-2007 Chevrolet Silverado 1500 4WD
- 2005-2007 GMC Sierra 1500 4WD
Last edited by blazerboy001; Jun 17, 2010 at 10:48 PM. Reason: It's amazing what a google search can do. lol
gmoney30
Jul 5, 2010 08:51 PM
gmoney30
Jan 22, 2010 07:07 PM
