Let’s put a 5.3 in it
Old Apr 1, 2021 | 11:41 AM
  #51
BMF's Avatar
BMF
BMF is on a distinguished road
I can’t seem to get fuel pump to prime. Any help at this point would be grateful. I tuned vats out. I’ll check real quick and see if my grey wire sending 12 bolts or not
Old Apr 1, 2021 | 05:25 PM
  #52
BMF's Avatar
BMF
Added a external pump and it fired up
Old Apr 1, 2021 | 05:35 PM
  #53
I'm wondering if the pump was good?
Old Apr 2, 2021 | 11:08 PM
  #54
Hess13x's Avatar
Oil pressure bypass would be my guess on no fuel prime. Delt with that ages ago on a firebird that had a tbi 4 banger originally that I put a v8 in. Traced wires for days, then wired ahot key on straight to the fuel pump. Worked great for a few days lol. Ended up doing an external pump also.
Old Apr 10, 2021 | 08:32 AM
  #55
BMF's Avatar
BMF
I’m out of money. Lol not really but yeah. Ok so here is where I’m at. Steering is hitting the header. Gotta figure that out. Driveshaft appears to be to long. Truck sets real close to the ground so I’ve not climbed under to hook this up actually. Going to get it raised up today and take a look
Old Apr 10, 2021 | 03:23 PM
  #56
BMF's Avatar
BMF
Drive shaft is connected to transmission. I’ll show what I’m doing for the steering shaft tomorrow. Basically cutting shaft and milling down an insert to get the smaller diameter to clear header. Now back to the gosh dang wiring. And I still don’t have a book to pin out what is what. I’ll post a pic. I’m guessing I need to find out what this controlled
Old Apr 10, 2021 | 03:26 PM
  #57
BMF's Avatar
BMF
Any help on what this controlled or a pin out it’s pretty much all I have not hooked up yet
Old Apr 22, 2021 | 10:44 AM
  #58
jimspahr@msn.com's Avatar
Are you using a 'SpearTech' installation harness? they design harnesses to install V8 engines into other than the original car or truck.
Old May 4, 2021 | 07:26 PM
  #59
BMF's Avatar
BMF
No I made harness myself. So here’s where I’m at. Runs and drives perfect in reverse. Forward not so much. If someone can tell me how to show a video I have one
Old May 5, 2021 | 09:34 PM
  #60
ChuckNTruck's Avatar
Looks great! It will be a blast once you get it done and get to rip around in it.
Looking at some pin outs it seems like some of the vital engine stuff runs through that C100 plug and may be the reason for fuel pump priming issues. Oil pressure sending unit, ignition voltage, ECM data, etc.
This may help you with the wiring harness pin outs.
pages for the 2002 harness
https://lt1swap.com/vortec_truck_pinouts/2002.htm
Page that has other years selectable on it.
Vortec 4.8/5.3/6.0 Wiring Harness Info
