My bike 'Jenna'
Old Aug 25, 2013 | 02:43 AM
  #201
Thogert's Avatar
Well today I found out that my clutch is going bad. It's doing a lot of whirring when I pull the clutch in, it's been slipping at high torque for a while, and it doesn't start to disengage until it's almost pulled all the way to the handle bar. So looks like that will be the next project.
Old Aug 25, 2013 | 08:23 AM
  #202
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Can you adjust it?I know my bike is much older than yours but I can adjust the cable where its goes into the side cover to the internal clutch inside.
Old Aug 26, 2013 | 06:37 AM
  #203
Thogert's Avatar
Yeah I thought about that. I haven't tried it yet though.
Old Aug 30, 2013 | 01:10 AM
  #204
Thogert's Avatar
I have ordered the new clutch and it should be here sometime in the next couple of days.
In the meantime, I decided that while the bike was down, I'd start a smaller project.
If you can see it, there is a small gap in the middle to separate the two sides a little bit. There is a reason for this.... More info as this unfolds.
Attached Thumbnails My bike 'Jenna'-20130829_214625_zps4b33835c.jpg   My bike 'Jenna'-20130829_212041_zpsc74f5e74.jpg
Old Aug 31, 2013 | 12:38 AM
  #205
Thogert's Avatar
Ok so I basically got the tail light done today.
Here's the difference from parking to brake.
This also shows the fact that I wired each side separately. I did this so that I can wire up the turn signals to each side. I have yet to do the extra wiring (it includes a couple of diodes, tapping into the turn signals, and using either two 5pin relays, or those magic flasher things) but the brake light function is all wired up and installed.
Parking
Brake
Attached Thumbnails My bike 'Jenna'-20130830_195009_zpsb704a2cd.jpg   My bike 'Jenna'-20130830_195015_zpsfa5cb08f.jpg   My bike 'Jenna'-20130830_202156_zps40fc984c.jpg   My bike 'Jenna'-20130830_215008_zps8c3cf39b.jpg   My bike 'Jenna'-20130830_215048_zpse648dfef.jpg
My bike 'Jenna'-20130830_215059_zps10e87299.jpg   My bike 'Jenna'-20130830_215219_zps695b2fe6.jpg
Old Aug 31, 2013 | 05:33 PM
  #206
Thogert's Avatar
I got the clutch in today, and quickly installed it. Only took about 1.5 - 2 hrs. The handle did need a little adjustment (thanks for the idea btw) but the handle is a lot stiffer than before. I have yet to ride it as I didn't bother to soak the plates in oil prior to installation, but it should be good to go tomorrow.
Old Aug 31, 2013 | 05:48 PM
  #207
xgiovannix12's Avatar
Nice progress
Old Aug 31, 2013 | 07:01 PM
  #208
Thogert's Avatar
Yeah the new springs I got for the clutch will take some getting used to though.
Old Sep 1, 2013 | 08:27 AM
  #209
On my bike the clutch is fine for now but I might change to some stiffer springs at a later point.
For now Im replacing the rear brakes which failed on me yesterday.
BTW I like the tail light and noticed that you can light up half of a side is it hooked up to the turn signals?Because of my bikes charging system works and its much older its difficult an expensive to switch over to the led lights.Some guys have done it but you hav make alot of changes for it to work.
Old Sep 2, 2013 | 02:18 AM
  #210
Thogert's Avatar
Right now the signals are not hooked up. I'll get around to it sooner or later.
So I rode it today, and the clutch feels great, but the problem with it bogging down and surging showed it's ugly head again. I'm thinking the carbs are having issues, so hopefully a new jet kit will solve that.
What's the issue with your charging system?
Oh, and here's a pic I like.
