My bike 'Jenna'
Old Sep 2, 2013 | 03:31 AM
  #211
Dobe Rottie Gang's Avatar
Dobe Rottie Gang is on a distinguished road
Love the brake light, just wondering if I could do that on my Harley and what's involved.
Old Sep 2, 2013 | 10:04 AM
  #212
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Seee if I can explain it the best I can,For one my engine runs off battery power so the altenator is continuesly charging making voltage.This voltage gets sent to rectifier/regulator which converts the current into a continues stream of 12 volts to the engine and the lights.
On your bike since its much newer than mine I dont beleive your engine needs the battery to run.It has a self sustaining charging system from the stator and generator.In order to run led`s you have to split the voltage by adding capacitors and diodes so that the leds arent requiring a continous 12 volts and decrease the voltage in order for them to work.I know theres more to this but the elctronics are not my strong point on these bikes.
Old Sep 2, 2013 | 12:48 PM
  #213
Thogert's Avatar
It's not too difficult of a process if you have a basic grasp on simple circuits and soldering.
First you would need a board to attach all of the leds and components to. Something like these would work fine, just make sure the one you get is big enough to fill the light housing you are using.
Next you would need to know what kind of led you will be using. I highly suggest you use the HPWT leds from Phillips that I used, which can be found on ebay, but do not be fooled, there is a lot of chinese crap out there.
After that you'd need to open up the tail light housing to get the board in there, which can be difficult, so I'd recommend buying a new one and working on it instead of the stock one just in case you break it or mess it up somehow.
Then you'd trim the board to the inside of the housing so it fits snug.
Once that's all done you'd need to decide how you want to arrange the leds on the board. Definitely make sure you leave at least one little hole in between the leds to make soldering them easier.
Solder them all in place and wire them up and you are good to go.
If you do decide to do it, make sure to post a new thread (probably in the lighting and electrical section) and richphotos and I can help you with any questions you may have on wiring or any part of the process really.
Well it sounds like you could just use a voltage regulator to make sure the leds aren't starving for power and go from there. What you should remember is that taking any incandescent bulb out of the circuit and replacing it with an led array will free up a good amount of power for everything else. Even if your bike runs off the batt. continuously, so long as it's in the 10 - 15v ballpark a voltage regulator can overcome any fluctuation and allow the use of leds. You would still need resistors for the leds, but no diodes or capacitors. (so long as you don't go for the flashing part of the brake light like I am.)
Old Sep 2, 2013 | 12:54 PM
  #214
[QUOTE=Thogert;599226]It's not too difficult of a process if you have a basic grasp on simple circuits and soldering.
If you do decide to do it, make sure to post a new thread (probably in the lighting and electrical section) and richphotos and I can help you with any questions you may have on wiring or any part of the process really. QUOTE]
Thank you very much for the info.
Thankfully I have a spare rear light that I got on eBay but with everything never got around to fitting it, so it looks like I'm going eBay hunting again tonight for the parts.
Old Sep 3, 2013 | 01:34 AM
  #215
Thogert's Avatar
Well my camera sucks big hairy monkey ****, but here's a vid of the turn signal tied into the brake lights. IRL you can see that it's only half flashing. The way I have it wired, the brake light overrides the flashing of the turn signal portion so as to make sure people know I'm stopping.
20130902_232742_zps36980bce.mp4 Video by thogert | Photobucket
Old Sep 3, 2013 | 08:15 AM
  #216
That light should do the trick,I would like to have a front head lamp that does that along with the rear.
Also yesterday I removed my rear sprocket since its totaly worn.Im also going to upgrade the teeth from 37 to 38.Then decrease the tooth count on the front from 17 to 15.This should knock off a big chunk of high rpms at cruising speed.
Old Sep 3, 2013 | 11:39 PM
  #217
Thogert's Avatar
Be careful you don't take away too much bottom end power.
Well I ordered the jet kit today with the K&N pod filters and a water repellent filter cover for when I get caught in the rain.
Should look something like this.
Old Sep 4, 2013 | 11:04 AM
  #218
Yeah I had the teeth count for my ratios that I was wanting.So what I`ll be doing is decreasing teeth count on the rear by 1 and increase the teeth count by 2 on the front.Theres a thread about it on XS400.com
Old Sep 4, 2013 | 11:08 AM
  #219
rexmburns's Avatar
Super Moderator
I was about to comment on your first post about going down in the front and up in the rear but you corrected it with this post lol. More teeth in the back and less up front means lower gear which of course you know means higher rpms.
Old Sep 9, 2013 | 10:31 PM
  #220
Thogert's Avatar
Sooo, I got this in.
Which led to this:
I got it together and took it for a spin and I must say the thing sounds awesome. It is running a little rich at the moment, so I need to remove one of the needle shims due to living at over 3000ft, but overall, $ well spent.
I'll get a pic of how the filters look tomorrow, and maybe a short vid if my phone will do it any justice.
Attached Thumbnails My bike 'Jenna'-20130909_172503_zps69d55b88.jpg   My bike 'Jenna'-20130909_190821_zpscef40d8c.jpg
