My small 96 Blazer build
Old Jan 23, 2013 | 01:25 AM
  #281
Diaita's Avatar
I just went with this cause it was cheap and matches pretty close. I have no complaints besides when they roled it I had one spot with a small crease but once I stretched and glued it it went away without issue. It stretched around and over the curves and egdges really well to. 1 yard was all I needed for the back.
Thanks! Just what i like, inexpensive!
Old Jan 24, 2013 | 08:12 AM
  #282
rexmburns's Avatar
Super Moderator
Yeah for the price I do don't have any complaints. Its actually a tad thicker than I expected it to be.
Old Jan 31, 2013 | 07:19 AM
  #283
Copperhead 2001's Avatar
Copperhead 2001 is on a distinguished road
Hey REX quick question for you. going back quite a bit, did you use a roller on your bedliner? it looks really even, and uniform.
Thanks
Old Feb 1, 2013 | 07:02 AM
  #284
rexmburns's Avatar
Super Moderator
Yeah I used the roller that came with the monstaliner kit.
Old Feb 1, 2013 | 12:49 PM
  #285
rexmburns's Avatar
Super Moderator
Well its only taken me most of the week working on it here and there but I finally have all of my wiring complete!! I made a total of 6 wire harnesses for the project but it was well worth it cause everthing is nice and tidy and looks nice. I didn't get pics of all the harnesses I made cause it was cold and I didn't even think to take pics
We will start with the switches I suppose.
And then I also restretched and fixed the top of the switch panel so it looks better. This is with all the wires attached and tucked away
Then under the hood I made up a small spot to mount some relays and keep them out of the way. They are all wired and all I have to do is run one power wire to the relay and whatever I connect to it and I'm done for the additional two relays I am going to add one more relay I just didn't have one at the time but it will be coming and the wiring is already there from the swtich for it as well.
And heres a shot of the whole engine bay after everything is wrapped and cleaned up
Then on the roof I ran the wires through a hole I drilled under the support leg for the factory roof rack so that no wires would be running through doors and looking out of place. I decided to use "2 flat" connectors on everything cause they serve their purpose and they were only $3 a piece at Advance Auto.
I used the same connectors for all of the lights as well so now it is set up that I can remove my enitre roof rack by just unplugging one connector or I can remove lights individually if necessary.
The connector tucks away nicley inside the rail and is hidden away a bit.
And after all of that this is what I ended up with.
Attached Thumbnails My small 96 Blazer build-dfd704e7-2231-4483-a832-78f1fe72cee4-727-000000c77d83aa50_zps71aa5559.jpg   My small 96 Blazer build-3dbc2e23-dde3-47dc-ad0d-4b826e0bc546-727-000000c7549c84cb_zps8901ac6a.jpg   My small 96 Blazer build-7c3d3178-76d2-43c2-88c4-6f9892338ab2-727-000000c88428dbc3_zps74fa5b12.jpg   My small 96 Blazer build-cff07d53-2f37-4dc7-aea8-e95a833349cf-727-000000c75bf40888_zpsd66668d3.jpg   My small 96 Blazer build-ab83852b-3d91-4bd3-87d0-aef304924669-727-000000c87ea74ae3_zpsc0b1c755.jpg
My small 96 Blazer build-bddfa090-4d18-47f8-9b31-ae06b7f12ed4-727-000000c731a5438b_zps2ecf3b76.jpg   My small 96 Blazer build-6827a263-b65a-4022-b8e2-c25400e22eba-727-000000c7117d4933_zpsb26e406c.jpg   My small 96 Blazer build-2c1f9e8d-79d1-46dd-80c2-acf9f12e917f-727-000000c874128bba_zps26875567.jpg
Old Feb 1, 2013 | 01:03 PM
  #286
TheRandom1's Avatar
Looks good! Any plans to label the switches, or just going to remember which is which?
Old Feb 1, 2013 | 01:10 PM
  #287
rexmburns's Avatar
Super Moderator
Yeah I'm searching for a non cheesy way to label them. For right now I only have two things running off of them so I know which is which but I will need to do something for sure I'd hate to have the wife throw on the roof lights at night and blind someone lol!
Old Feb 1, 2013 | 03:16 PM
  #288
matt9589's Avatar
matt9589 is on a distinguished road
looks good! Wanna wire my lights to!!???!!?
Old Feb 1, 2013 | 03:37 PM
  #289
rexmburns's Avatar
Super Moderator
Thanks!! Haha it took way longer than I wanted to but I wanted it done right so I don't have to worry about touching it later.
Old Feb 5, 2013 | 12:54 PM
  #290
rexmburns's Avatar
Super Moderator
Well I came back to work late last night to drop off my work truck and decided since it was dark out I would drive down in the woods and see how well my new lighting setup worked. Heres a couple pics.
Sorry for the crappy iphone pics! The manhole is about 50 yards away.
Factory high beams
The same zoomed in a bit
2 Prerunner bar lights and factory highs
2 prerunner bar lights factory highs and three roof lights
I want to add two flood pattern lights to the roof in between the two outer spots but I'm happy for now.
Attached Thumbnails My small 96 Blazer build-1e88d179-ee18-4aa3-8012-31c703674f1f-2199-0000022375cab512_zps647dc295.jpg   My small 96 Blazer build-3dce71cd-e821-4052-b3d1-16a1869be025-2199-000002238000b71a_zps41339790.jpg   My small 96 Blazer build-8c1e3101-a4cd-44fb-a548-298593b2e773-2199-00000223882e6e36_zps826b82aa.jpg   My small 96 Blazer build-0c148f27-e2f3-4aa2-a05e-3ace925b6955-2199-00000223a249b097_zps523fca03.jpg   My small 96 Blazer build-09dae57b-e56f-42f4-85df-66586ebff9e8-2199-000002239aaaa2c1_zps7a62d76d.jpg
My small 96 Blazer build-b0251cbe-38e3-4454-b987-5e9282fa1733-2199-000002238e14ed5b_zpsa969b955.jpg
