My small 96 Blazer build
Old Apr 15, 2013 | 12:19 PM
  #401
rexmburns's Avatar
Super Moderator
Originally Posted by cleburne red
That would be nice! No hurry, though, just when you get a chance. I had looked into grill/brush guards before, but there aren't any, really, for '95-'97 Everything seems to be for '98+. I really like the style of the baja challenger/eliminator. It's different from all the guys in 3/4 ton trucks with ranch hands around here.
Here are pics of the mounting points. In the first pic you can see that it is just a hole drilled in the top of the bumper and a bolt goes thru the bar and bumper and there is a nylock nut on the other side. There is also a rubber grommet inside the bar that is supplied as well.
In this pic the hex bar is welded to the bar and threaded on the inside so you drill a hole in the front of the bumper and thread a bolt into the hex bar from the inside of the bumper.
And that's it! Its incredibly simple
Attached Thumbnails My small 96 Blazer build-9d880760-4052-425f-9bb3-8ca9108191f2-12313-000009d571992caa_zpsfd0eda92.jpg   My small 96 Blazer build-40210215-163f-4594-9ea7-2ec2bbd100d2-12313-000009d56c8aa2ef_zps519924ae.jpg
Old Apr 15, 2013 | 12:20 PM
  #402
rexmburns's Avatar
Super Moderator
Originally Posted by Jimmy_Blazer
Ok so this question is a bit late, but how did you attach the front hitch receiver to the frame?
I pulled the stock tow hooks and then put the receiver tubes inside the frame rails to mark the holes of the tow hooks and the skid plate bolts. Then drilled out where I marked and used some grade 8 hardware to bolt the receiver tubes in.
Old Apr 15, 2013 | 12:25 PM
  #403
rexmburns's Avatar
Super Moderator
Originally Posted by WalkGood
Just a polite reminder ... :-)
So sorry I completely forgot to respond to you my bad!!
I pulled the fans from a 00' Dodge Intrepid at a PNP.
The on/off switch is so that if I ever want/need to turn the fans off completely say for a water crossing or something I have the ability to do so. Just a little extra control over them really.
Yeah the temp sensor is in the 3rd or 4th row of the rad near the intake hose. It just a push in type that I may one day swap out for a thread in but its working great for now so I will leave it alone
Old Apr 15, 2013 | 04:49 PM
  #404
cleburne red's Avatar
Thanks Rex! That's what I needed to see. Is it pretty sturdy? I don't plan to push disabled vehicles out of the way, but I don't want it flopping all over the place, either.
Also, is it fairly easy to get behind the bumper to attach everything? I've already got the valance off, so it shouldn't be too bad.
Old Apr 16, 2013 | 12:43 PM
  #405
rexmburns's Avatar
Super Moderator
Got the jimmy hood painted and wet sanded. Still have about 4 coats of clear and more wet sanding after that but I ran out of clear. Well anyway here's some pics
2 coats of primer
I think this is coat 2 of black
6 coats of black and some wet sanding
And a coat of clear on the truck
I also sanded out the fade marks on the tailghts from the POs taillight covers and recleared them
Before
After on the right
I'm happy with how they turned out. I also did the bumper blinkers and headlights a bit but no pics sorry
Attached Thumbnails My small 96 Blazer build-5c2835e0-b8e2-4f3e-aa84-ec37357a4c30-12313-000009d58b039d27_zps10ed2295.jpg   My small 96 Blazer build-5a67d46d-647e-4535-bd78-1c9ae59d7fab-12313-000009d576da30e2_zpsbc531e69.jpg   My small 96 Blazer build-6310c413-7f99-448c-9e79-7fdc7f08e2e1-13266-00000a3ce577c649_zps10bbe009.jpg   My small 96 Blazer build-1f240933-7516-4df2-9996-fa8133e379c1-13266-00000a3cbc768374_zpsc5c74719.jpg   My small 96 Blazer build-b9c82742-d1af-4958-9aa9-b97bb1114fb4-13266-00000a3cdb93c0df_zps70582a1a.jpg
My small 96 Blazer build-d07f7d2b-3d76-45df-9b00-498a7eed4f96-13266-00000a3cfc5d1f02_zpsdbc52f64.jpg   My small 96 Blazer build-dccef869-7ea3-4bb0-8c8d-16b5fec30495-13266-00000a3cf6fe9f9b_zps98babe08.jpg
Old Apr 16, 2013 | 12:47 PM
  #406
rexmburns's Avatar
Super Moderator
It's actually very sturdy! The bar itself is heavy probably 60lbs or so. I would recommend marking everything up to where you need the holes and then pull the bumper off and mount the bar. It's just kinda hard to get to the center bolts with it still on the truck. The only complaint I have about it is that you have to move the bumper out of the way to pull the grill off but as little as I take my grill off I really don't care all that much just figured I'd let you know.
Old Apr 16, 2013 | 12:52 PM
  #407
gitch93's Avatar
gitch93 is on a distinguished road
looking great rex keep up the good work
Old Apr 16, 2013 | 01:11 PM
  #408
rexmburns's Avatar
Super Moderator
Thanks gitch!
Opinions please yes or no on the bug shield thingy?
Attached Thumbnails My small 96 Blazer build-403238cf-a9ae-40da-a309-8a19531fb761-13391-00000a4a4fb60526_zpsff1a15e5.jpg   My small 96 Blazer build-448eb33c-88fc-4324-badc-fddbb09e1df6-13391-00000a4a49dc09f0_zps9459e95e.jpg
Old Apr 16, 2013 | 02:53 PM
  #409
sickman420's Avatar
sickman420 is on a distinguished road
No bug shield! Unless your over 50, then put one on, along with a set of aluminum running boards and a set of corner markers and curb feelers.
Old Apr 16, 2013 | 03:08 PM
  #410
richphotos's Avatar
I had a bug shield on the jimmy when we got it, it made it a year before I took it off. hated it.
