New
Old Apr 8, 2019 | 08:59 PM
Kylegloer's Avatar
Kylegloer is on a distinguished road
Default New
Badges removed and front gmc logo blacked out. Already put in new spark plugs, distributor cap, rotor and also new ball joints
Rims are getting sand blasted, and painted black
Old Apr 9, 2019 | 07:25 AM
Looks good... what plans do you have for her?
Old Apr 9, 2019 | 08:22 AM
Kylegloer's Avatar
DonL, thanks, the plan at the moment, is to get the rims painted black.
and when the time comes i will hopefully be getting some bf goodrich ko2 tires.
i am also going to be getting a new gibson cat back exhaust in summer,
any suggestions of things to do or look over?
Old Apr 9, 2019 | 08:46 AM
Depending on mileage, keep an eye on your antifreeze level. The lower intake manifold gasket tend do go, time consuming job but not the hardest. Hubs and steering components, if you spend more time on pavement you should be good. A lot of blazer get "back end sag", new leaf springs/add a leaf kit/lift shackles will solve this. Try not to adjust your front ride height with the torsion keys, you will cause more wear on parts...
I for one would look into hub centric spaces for the rear, 1.25"-1.5", a lot of people(including myself) have noticed better handling, and you have a few saying they are not recommended.
If you do want to do some light offroading with a little more clearance, the rough country 2.5" lift is good, or a body lift will accomplish the same.
Skid plates is a must as well for offroading, look for aluminum ones, but if carbon fiber ones are all you can find, it's better then nothing.
Old Apr 9, 2019 | 08:59 AM
Kylegloer's Avatar
DonL, thanks for the suggestions man, i would love to do that 2.5 inch lift soon, i live in canada woth lots of snow and i think that would really help out.
and the issue with the rear offset will be fixed with the new rims, i got 2 with a deeper offset to help push out the wheels just alittle bit, and the other 2 rims are the normal offset
Old Apr 9, 2019 | 11:30 AM
cleburne red's Avatar
What offset will your spare be? Might look funny if you ever have to put it on and have one oddball wheel lol.
Nice looking truck, though!
Old Apr 9, 2019 | 01:45 PM
I hear yea, I'm in Ontario. I did the 2.5 lift over a spand of a weekend. As well as I did an add a leaf. Good call on the rims, I thought about that, but I would need 2 spares, just because I would be bugged by the 1 nine matching rim, even if it's just to get to the shop lol...
Oh, forgot to mention, might be a good idea to check/redo 4x4 vacuum lines...
Old Apr 9, 2019 | 01:48 PM
Kylegloer's Avatar
DonL, yeah i am going to have my spare the same as the front tire, but i would not want 2 spares because that is alot of room being taken up especially iff your just driving around with them, even though it is different offset front and back they are still the same width and should be too bad for a day or too
Old Apr 9, 2019 | 05:41 PM
N. Jensen's Avatar
Those stock Jimmy rims are my 2nd fav S-Series wheels (just behind the ZR5 rims).
Pretty color, too...
MushMy4.3
Aug 31, 2012 04:42 PM
v8 jago
Suspension Tech
17
Nov 10, 2011 10:19 AM
93blazernick87
Lifting Tech
Mar 22, 2010 12:41 AM
Nate12
Aug 21, 2008 10:12 PM
s10 blazer dude
Lifting Tech
May 2, 2008 10:43 AM
