The Rookie Jimmy Experience
Old Jul 14, 2011 | 10:09 PM
  #21
TripleBlackBlazer's Avatar
I think 6 spokes on a 5 lug looks out of place, but that is merely my opinion.
Old Jul 15, 2011 | 02:24 PM
  #22
2000jim's Avatar
2000jim is on a distinguished road
I dont mind the six spokes its so hard to find 5X4.75 and i love the matte black im hoping it goes good with my jimmy
interior and exterior are black but i still need to tint the front windows.
Old Jul 27, 2011 | 10:57 AM
  #23
2000jim's Avatar
So my add-a-leaf came in today and was wondering if anyone had install tips to speed up the process or if anyone can tell me if the u-bolts are long enough to install the extra leaf spring.
Old Oct 13, 2011 | 12:48 PM
  #24
2000jim's Avatar
Thumbs up 3 months later
So been awhile sense a build update but here it is.
The rough country 3" add-a-leaf
t-bar crank
brush guard
tires and rims
spark plugs
ball joint
The add-a-leaf went good little longer than i thought so ill make sure to post it up with picks
the tbar was easy but weird. i got about 4.5 turns before my drivers side was maxed but my passenger side had lots of space?
Brush guard was a great deal and no now need to build a bumper just mod it a little for the winch.
was getting the tires and rims on yesterday and alignment but got told my lower ball joint was bad so i am currently learning to replace that now and going to do the spark plugs at the same time while the tires are off.
might consider doing brakes also to save time later. Any one have favorite brands for rotors and pads??
Thats all tonight, let me know what you think and the pics will be coming up tonight or tomorrow depending when i'm done the ball joint and spark plugs
Old Oct 18, 2011 | 12:13 AM
  #25
2000jim's Avatar
Default Add-a-leaf
Getting to some pics of the aal install it was surprisingly easy but took me way to long to finish.
First off I got the tuff Country aal and i cant remember the part number but just ask if you are looking to get one.
Procedure:
Undo Ubolts and take off shock
Jack up the rear axle
c clamp the leaf spring set and unscrew centering bolt!
then reverse!
For taking off and put on the nut of the centering bolt make sure you really clamp the leaf springs so there is as little pressure as possible on the nut. I ended up almost stripping both while uninstalling so that took a little extra time.
Other than that its a nice touch
The stock ubolts are long enough for the extra leaf to be added so nothing extra is needed when doing the install. A grinder is nice to cut off the extra long bolts of the new centering bolt.
Then just cranked the tbar 4.5 turns and was good to go.
Back is still higher but I'm happy with the lift and will be putting on 265/70/r16 silent armour tires tomorrow. Weird thing with the tbar crank was the drivers side. I could only crank it a max of 4.5 turns where as the passenger has much more room to be adjusted, either way I got the sides to equal heights so I guess it works out ok.
Attached Thumbnails The Rookie Jimmy Experience-photo-11-07-28-7-20-53-pm.jpg   The Rookie Jimmy Experience-photo-11-07-28-7-20-59-pm.jpg   The Rookie Jimmy Experience-photo-11-07-28-7-50-57-pm.jpg   The Rookie Jimmy Experience-photo-11-07-28-7-53-36-pm.jpg
Old Oct 19, 2011 | 04:31 AM
  #26
Tangvik1's Avatar
Tangvik1 is on a distinguished road
Nice project! Post some exterior pictures!
Old Oct 19, 2011 | 10:30 AM
  #27
2000jim's Avatar
here it is!
Pics will keep coming in to show the other stuff ive done
and the limited how too i know how to do haha
Old Oct 19, 2011 | 12:19 PM
  #28
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
that looks good. are you planning on removing the gray trim?
Old Oct 19, 2011 | 01:50 PM
  #29
2000jim's Avatar
I like the trim because it is the whistler blackcomb edition so I havent seen any others like it.
White lettering on tires gray trim on the truck and white strip around those all count as nice details..... right
Old Oct 19, 2011 | 01:54 PM
  #30
TheRandom1's Avatar
I've never heard of a "Whistler Blackcomb Edition" what is it, exactly?
