Rough Country 2.5" Lift!!!!
Old Dec 14, 2011 | 09:39 PM
  #181
coop22's Avatar
coop22 is on a distinguished road
no dont have that happening, maybe your bars are cranked to tight? mine rides tighter but alot more controlled
Old Dec 15, 2011 | 08:22 AM
  #182
El Diablo793's Avatar
El Diablo793 is on a distinguished road
My bars are cranked tight, but both the mechanics that put it on and rough country said that if it is at the height (21") from the hub then it should be fine. Ill get under it today...maybe its something stupid like the bump stops. Idk.
Old Dec 15, 2011 | 09:58 PM
  #183
coop22's Avatar
I think my ride height is higher, maybe 22 or 23" I'll have to check that. How much they charge you to install the lift?
Old Dec 15, 2011 | 10:07 PM
  #184
coop22's Avatar
went out and check height 22 3/4"
Old Dec 16, 2011 | 01:25 AM
  #185
killallblue's Avatar
killallblue is on a distinguished road
buying my lift in a few weeks im geting the add a leaf and steering stabilizer
Old Dec 16, 2011 | 05:03 AM
  #186
I may just have to modify my bumpstops then because if I lower my control arms then my tire will rub and i'll need another alignment. Its not that be, just noticeable on bigger bumps and makes for a rougher ride on those certain bumps because it tops out.
Old Dec 18, 2011 | 03:30 PM
  #187
p_m_clean's Avatar
p_m_clean is on a distinguished road
New to this site, Love all the info Iv had 6 s10s and always had problems with the suspension. But im an idiot and still love them. Pretty much want to know is anyone has beat on this kit yet, iv broke 2 front diffs so far both were in my blazer with the 5 inch trail master, which is garbage. besides the crappy shocks and the cutting of the front diff does this kit seem to be legit, I commute in my blazer but also want to be able to rally around a little bit and not have to worry too much about breaking bending and reliability any input would be great. the pics of the drop brackets look like weak what do you guys think
Old Dec 19, 2011 | 10:12 AM
  #188
coop22's Avatar
Sounds like you might need the soild axle conversion, anyway the drop brackets are solid pieces and the arms are good also. I have the rough country 2.5" and a 2" body lift. I'll try to down load a pic or two.
Old Dec 19, 2011 | 10:23 AM
  #189
coop22's Avatar
Old Dec 19, 2011 | 11:01 AM
  #190
Irocz327's Avatar
Irocz327 will become famous soon enough
The truck lookes good bud! I've been to busy to get around to doing the 2.5rc lift & 2in BL its nice to have an idea of where I'll be sitting thou. so thanks.
