Detailing Discuss detailing your Blazer within.
Engine compartment
Old May 26, 2010 | 03:58 PM
EzTec's Avatar
EzTec is on a distinguished road
Default Engine compartment
Hey guys. I was wondering if it's at all possible for someone to do a DIY write-up on how to do an engine detailing yourself, especially on the 2nd gen Blazers. After a recent trip to The Mounds in Mt. Morris, Michigan, the engine compartment could use a good cleaning.
Yeah, I know, . But, I was thinking someone might have found a good way to do an engine detailing. That, and I can't seem to find any good ones on the Blazers.
Old May 26, 2010 | 09:42 PM
Bigringtravis's Avatar
Bigringtravis is on a distinguished road
Foamy engine brite and a long bristle wheel cleaning brush. Rinse, repeat if needed.
After it dries a little bit, spray it with tire dressing. I like Armour-All Tire Foam - it dries like a glaze, and looks good for a pretty long time.
Hint though, and my best advice... Before you hit the trails, spray the wheel wells, suspension, and frame/under the cab with black magic tire dressing - It'll make clean up a WHOLE lot easier!!!
Please note, if you're muddin, nothing will keep the mud from sticking. Just wash before it dries!
Old Oct 8, 2010 | 03:43 PM
Sirloin's Avatar
Sirloin is on a distinguished road
I use Simple Green mixed 1:1 with water in a spray bottle, give it a good once over, then drive to the car wash and use the tire ( or engine ) cleaning setting on low pressure, then a low pressure rinse ( or spot free rinse ).
Old Oct 10, 2010 | 02:04 PM
Nemo1991's Avatar
Nemo1991 is on a distinguished road
are there anythings you should avoid getting wet under the hood? and i have a cai what should i do to prevent water from getting in there
Old Oct 11, 2010 | 11:02 AM
Sirloin's Avatar
Is your wiring and their connections in good condition?
Personally I do a visual check, and make sure all of the fluid caps ( and dipsticks ) are tight.
The CAI I'd just spray around it ( low pressure of course ), If you want to clean the filter, that's a different animal ( remove, clean and re-oil ).
I like to have the engine warmed up, so after the low pressure rinse, the engine compartment dries out on the way home ( you could lift the hood and let it air out when you park it at home too ).
If you wanted to do it at home you could use the simple green spray, a rinse spray and then compressed air to blow things off, using your home air compressor & an air nozzle.
I am sure you could find a really detailed explaination, but it really is easy & painless ... If you're in doubt ... give the engine a small bath this week ... then next week give it a little better bath etc. ... until you get the results you want.
Old Oct 11, 2010 | 06:05 PM
Nemo1991's Avatar
thanks sounds like a good idea. seeing that i detail cars for a living at a dealership i should know more about this lol, but they dont make me get so in depth with the cleaning.
Old Oct 11, 2010 | 08:57 PM
EzTec's Avatar
The only things I've been told to keep covered is the alternator. I haven't tried the 1:1 Simple Green. I'll give it a shot next time I do a cleaning under the hood.
ktryan
Sep 24, 2009 05:28 PM
macdaddy25177
Jan 14, 2009 12:38 PM
GABlazer92
Mar 24, 2008 12:26 AM
nflea7
Aug 14, 2007 12:36 PM
thanser
Jan 28, 2006 08:50 PM
