Detailing Discuss detailing your Blazer within.
Headlite covers clear(plastic) heavy wax build up
Old Dec 29, 2010 | 10:20 AM
mjsk5blazer's Avatar
mjsk5blazer is on a distinguished road
Exclamation Headlite covers clear(plastic) heavy wax build up
Whats the best way to remove wax from Plastic Lens covers (and driving light area) it appears to have a heavy build up of wax...........
I bought a polishing kit, but these aren't yellowed......just a heavy build up............
Its the whole cover both sides..........
Again thank you for any tips or helps............ hoping i dont have to polish them back up cause its rather cold here.......
Mj
PS: i had to use my polishing kit, there was no way around it...... i did get 99% of the film off, still alittle layer, will go and buy a better kit and it should be done...............
Old Jan 1, 2011 | 06:48 PM
Rottidog's Avatar
Yeah unfortunately but depending on what year it may be easy to remove the lights & do that in the comfort of your home.
Did you look in www.blazerforum.com/forum/forumdisplay.php?f=23 ? There's a lot of info there.
Old Jan 2, 2011 | 12:23 AM
rmart617's Avatar
rmart617 is on a distinguished road
Yeah, I would try taking off the lights and taking them in a garage or house to stay out of the cold. I know those cleaning packages are good for yellowing but not sure for wax build up. Wax is usually liquid repellant so I would recommend getting goo gone. Its cheap and you can find it in many craft stores. It removes basically everything. Try using that on it, its worth a shot considering its only like $3 for a small bottle of it.
Old Jan 2, 2011 | 06:49 AM
THANKS! i have goo gone here forgot all about it........ i did have to take one headlight cover off and bring it into the house, because the socket was broken for driving light fixed it with plastic epoxy.........
Sort warm out may try goo gone later today..........like i said the polishing kit got most of it but a final layer and it can only be seen when headlight is on......but the lights work 100 times better..........
Mj
jimspahr@msn.com
Dec 17, 2013 08:45 AM
swartlkk
Detailing
37
Oct 27, 2009 10:40 AM
Zyan
Tires and Wheels
May 7, 2009 01:41 PM
92txblazer
Detailing
Aug 13, 2008 11:02 PM
