Detailing Discuss detailing your Blazer within.
Oh so beautiful
Old Jun 24, 2009 | 09:04 PM
mr.hotrod's Avatar
mr.hotrod is on a distinguished road
Default Oh so beautiful
okay so my little niece was over at my house with her mom and she came over to me holding something....the 4x4 emblem from behind the drivers door it had fallen off. Now to the point how do i get the black gunk off the pillar
Old Jun 24, 2009 | 09:08 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
goo gone, an eraser wheel, use your thumb or any other adhesive remover will do the trick.
Old Jun 24, 2009 | 09:12 PM
mr.hotrod's Avatar
ive tryed all but the goo gone i cant even get through it with a pocket knife it still sets a couple mm thick. its soo agrvatinghelp mee
Old Jun 24, 2009 | 09:27 PM
mikeinwi's Avatar
even an eraser wheel didnt work?? hmmm id say spray some goo gone on there and let it soak for a few minutes then try again. you could try simple green too i know a few guys that have had success with that otherwise you could try useing a razor blade to scrape it off(depending upon how steady your hand is)
Old Jul 2, 2009 | 12:51 AM
mdehoogh's Avatar
Don't give up, it will come off eventually. When I debadged mine, those badges on the B-pillar seemed like they could have been the hardest to remove. I finally got a corner of it up and it came off clean without much residue left over.
Granted, without the emblem on there, its harder to remove the adhesive but you will eventually get it. Good luck
Old Jul 2, 2009 | 04:25 PM
blazerguy22's Avatar
use a razor blade and very gently slide it along behind the goop should work but be careful not to cut into the paint that can cause rust which = not good and when i debagged mine i simply used an eraser wheel
GodTheTerrorist
Performance & Brainstorming
Jan 25, 2011 09:28 AM
blazertitan918
Feb 9, 2010 01:31 PM
ejschultz
Dec 12, 2009 07:47 PM
nj4x4blaze
May 28, 2008 07:58 AM
