1.6 rocker arms
Old Dec 14, 2012 | 04:15 AM
  #21
J_E's Avatar
J_E
J_E is on a distinguished road
I just finished this swap on my 2000 2dr. It probably has 30 mins of run time on it due to other work being accomplished.
I used the Scorpion 1.6 rockers, comp cam bee hive springs and the correct retainers. It did not require any head work. However I had my heads milled and valve seats and valves worked due to the PO driving a long time with bad intake gaskets, and a head gasket in the early stages of going.
The early stamped metal valve covers fit with out any machining/ grinding required, unless you want to remove the valve covers without taking the accessory brackets off.
I have read that you don't need to machine the guides until you add in an aftermarket cam and go above a certain lift. I stayed with the stock cam for the moment.
I forgot to mention, I used the stock pushrods.
Old Jan 6, 2015 | 11:19 AM
  #22
stevenc1522's Avatar
stevenc1522 is on a distinguished road
Originally Posted by jrrybrwn
I was told as long as ya use 1.6 3/8 stud self aligning and ya use your pivots from the 1.5 they will work.... the part I cant remember is if you need longer pushrods or if the stock will work.
Hey . I did cammed my car but i just install the cam and the sprins .but i also have the 1.6 roller rockers high energy push rods arp studs and i want to know if put this i need a special adjustment with the timing set
Pyro_fighter
Nov 13, 2012 03:23 PM
MikeRo
Apr 6, 2012 09:08 PM
2000TAHOEMAN
Jan 1, 2011 08:27 PM
magnum434
Sep 21, 2009 10:47 AM
Baja Blazer 85
Engine & Internal
Jun 1, 2009 08:55 AM
