1999 Blazer, RPMs FLuctuating,
Old Sep 7, 2009 | 07:54 PM
rocketrich's Avatar
rocketrich is on a distinguished road
Default torque converter
Is the check engine light on? P1870 code? if so the problem is the transmission valve body is worn where the torque converter lock-up valve lives, transgo makes a shift kit that will fix this problem, you will have to pull the trans pan off and valve body, in order to install, has worked every time for me.
Old Sep 8, 2009 | 10:07 AM
97jimmy4x4's Avatar
97jimmy4x4 is on a distinguished road
take the dist. cap off and see if u can move the rotor side to side as in if there is any play in the dist shaft. if there is the gear and the bushings are worn causing the timing to jump around. this happened on my 97 it would do it when u got on the highway. we hooked up a tech 2 and watched the timing jump around as the air gap on the sensor was changing from being worn. we removed the dist. and half the teeth were gone on the gear. replaced the dist. and has ran great ever since. before checking this i replaced everything from plugs to ignition module. and still nothing. check it out wont hurt.
Old Feb 26, 2010 | 02:21 AM
upmaine's Avatar
upmaine is on a distinguished road
Default RPMS fluctuating
I just had the same problem with my 99 blazer and it was the crankshaft sensor that was bad. I replaced it and now everything is fine.
Old Feb 26, 2010 | 05:39 AM
vanillathrilla's Avatar
vanillathrilla is on a distinguished road
What about bigger tires? Are you running bigger tires? I think that's the culprit for my RPM's jumping around on the highway. It acts like it wants to shift up then down then up sometimes at certain speeds.
Old May 7, 2010 | 03:05 PM
mickfrisco's Avatar
mickfrisco is on a distinguished road
Default Throttle Position Sensor?
I have the same problem in my 98 blazer. I havent fixed it, but I thought it was the throttle position sensor, since the symptoms are similar. But now i know it could be any of these things. Wow
TheSheepDog
Apr 7, 2014 12:54 AM
DannyD
Sep 30, 2010 07:57 AM
sorensic42
Jan 18, 2007 12:06 PM
ssilk12001
Sep 14, 2006 01:16 AM
dashyman
Aug 29, 2006 01:05 AM
