96 4.3 SCFI to MPFI Swap info needed
Old Nov 14, 2006 | 02:07 AM
AleroGuy's Avatar
AleroGuy is an unknown quantity at this point
Default 96 4.3 SCFI to MPFI Swap info needed
anyone have a how to on the scfi to mpfi swap?
things like the part numbers would be espically helpful. thanks
Old Nov 14, 2006 | 02:17 AM
Default RE: 96 4.3 SCFI to MPFI Swap info needed
I do believe i have posted part numbers before. Are you wanting to do it for performance reasons or to replace a faulty SCFI unit? Cause there will be pretty much no performance difference.
Anyway, here's where I posted the PNs:
https://blazerforum.com/fb.asp?m=30138
Old Nov 14, 2006 | 02:24 AM
AleroGuy's Avatar
i have a faulty unit in my blazer.
thought it might be the converter causing my bad fuel milage/stumbling/etc but i punched the honey comb outta the cat this past weekend and while the truck now runs better....... its still has the same problems jsut not as severe.
Old Nov 14, 2006 | 02:30 AM
AleroGuy's Avatar
i thought there was a bracket that needed to be replaced as well...... and also a "nut kit" or am i wrong and do i just need the mpi for my year blazer
Old Nov 14, 2006 | 02:47 AM
If you have the newer SCFI (plastic upper plenum), then all you need is the MPFI spider.
glcblazer
Apr 11, 2014 04:49 PM
4.3l trouble
Sep 2, 2010 09:01 PM
Patrick_Boyle
Aug 22, 2009 05:28 PM
neogeo92
Sep 27, 2005 02:12 AM
