FOR ALL YOUR MOTOR NEEDS
Old Mar 13, 2005 | 09:58 AM
02 Vortech's Avatar
02 Vortech is an unknown quantity at this point
Default FOR ALL YOUR MOTOR NEEDS
Hey yall since victoryredblazer turned me onto machperformance.com i cant beleive my eyes or the amount of money im probably going to dish out this summer for their parts.
if you want a new valve train package they got it
Valve train Package 1996-2003 +$520.00
(Specify year when ordering)
Parts Includes: Comp Pro Magnum Roller Rockers,
Diamond/Trend Pushrods, Rocker Arm Conversion Studs &
Valve cover Spacers.
if you want a whole new internal set up, they have 3 packages
Stage I Short Block (customer’s core, no disassembly) $3100.00
Parts Include:
SRP Pistons and standard wrist pins, Moly Rings, Camshaft, stock replacement lifters, new GM stock replacement timing chain & timing cover, ARP Rod Bolts, ARP Main studs, cam, rod & main bearings, new freeze plugs & oil galley plugs, Melling Oil Pump & pickup.
Machining Includes:
Degrease Block, Magnaflux Block, Bore/Hone with Torque Plate, Align Hone Main with ARP Main Studs, Parallel Deck Block, Balance Rotating Assembly, Degrease & Polish Crankshaft, Recon. Connecting Rods with ARP Rod Bolts, Pin Fit small end of rod and piston pin bore and complete short block assembly.
Stage II Short Block (customer’s core, no disassembly) $3835.00
Parts Include:
Diamond Pistons, Tool Steel Pins, Eagle Rods, Moly Rings, Camshaft, Anti pump-up lifters, new GM stock replacement timing chain & timing cover, ARP main studs, cam, rod & main bearings, new freeze plugs & oil galley plugs, Melling Oil Pump & pickup.
Machining Includes:
Degrease Block, Magnaflux Block, Bore/Hone with Torque Plate, Align Hone Mains with ARP Main Studs, Parallel Deck Block, Balance Rotating Assembly, Degrease & Polish Crankshaft, Race Prep Connecting Rods, Pin Fit small end of rod and piston pin bore and complete short block assembly.
Stage III Short Block (customer’s core, no disassembly) $4635.00
Parts Include:
Diamond Pistons, Tool Steel Pins, Eagle Rods, Moly Rings, Camshaft, Anti pump-up lifters, New GM stock replacement timing chain & timing cover, ARP main studs, Billet Main Caps, cam, rod & main bearings, new freeze plugs & oil galley plugs, Melling Oil Pump & pickup.
Machining Includes:
Degrease Block, Magnaflux Block, Bore/Hone with Torque Plate, Align Bore & Hone Mains with ARP Main Studs, Parallel Deck Block, Balance Rotating Assembly, Degrease & Polish Crankshaft, Race Prep Connecting Rods, Pin Fit small end of rod and piston pin bore, deburr block, and complete short block assembly.
+ core charges
and gasket kits
and head packages
Old Mar 19, 2005 | 12:50 AM
victoryredblazer's Avatar
victoryredblazer is an unknown quantity at this point
Default RE: FOR ALL YOUR MOTOR NEEDS
when I relocate to wisconsin and my warentee is up I will probably pay them a visit....
Old Mar 22, 2005 | 12:02 AM
02 Vortech's Avatar
nice, o yeah dude- while on summit i found a set of summit spark plug wires w/ spiral core 8mm for our 90 degree v6 motors for somethin like $35 + s/h im thinking about selling my msd's for like $100 and gettin the summits just to save some money
lefty807
Apr 9, 2013 06:02 PM
MrJP
Tires and Wheels
Feb 17, 2010 04:14 PM
bigvmc
Feb 19, 2009 05:21 AM
95Blazer4x4
Jan 30, 2008 09:18 PM
jng2523
Oct 8, 2006 02:50 PM
