engine swap question
Old Jan 27, 2008 | 09:11 PM
mudd's Avatar
mudd is an unknown quantity at this point
Default engine swap question
first i have a 85 s10 auto. i have seen a few things about the 350 but i have heard the camreo from i think a 94 95...???? will fir with the 700r trans. How much work is it? and how common is it?
Old Jan 27, 2008 | 09:51 PM
Zed's Avatar
Zed
Zed is an unknown quantity at this point
Default RE: engine swap question
2WD or 4WD ??
They all slide in pretty good !
Old Jan 27, 2008 | 10:48 PM
mudd's Avatar
4wd
Old Jan 27, 2008 | 10:55 PM
Blazin_Jason's Avatar
If your current engine is not a 4.3, then you will need a different tranny. Are you wanting to put in a v8 350, or are you just referring to a camaro engine like a 3.4L? What size engine do you have now 2.8?
Old Jan 27, 2008 | 10:58 PM
chevcamls1's Avatar
chevcamls1 is an unknown quantity at this point
only the v6 camaro fits that tranny the v8 has a 4l60e
Old Jan 27, 2008 | 10:59 PM
mudd's Avatar
i was talking about the camro the 3.4...i have the 2.8 now
Old Jan 27, 2008 | 11:03 PM
Then yes you can take a 3.4L camaro engine and bolt it to your 2.8 (60 degree as it's referred to, because of the bellhousing) transmission. I don't know what more would be involved, but it should be a simple R&R I would think.
Old Jan 28, 2008 | 12:53 AM
slammins15's Avatar
slammins15 is an unknown quantity at this point
x
Old Jan 28, 2008 | 02:50 PM
mudd's Avatar
thanks for all the info!
gmoney30
Jul 5, 2010 08:51 PM
SureShooter29
Mar 18, 2010 03:02 PM
gmoney30
Jan 22, 2010 07:07 PM
wesmagyar
Feb 16, 2008 12:19 PM
mortalum620
Engine & Internal
Aug 17, 2006 01:24 AM
