Help! Problem with 96 blazer
Old Jun 24, 2011 | 10:56 AM
Luis92's Avatar
Luis92 is on a distinguished road
Smile Help! Problem with 96 blazer
hello guys i found this forum after months of searching on the web trying to find a fix for my chevy blazer, well the problem is that my blazer has the ¨check engine light¨ turned on, it has that problem arround 5-6 years, every time i turn on my blazer the check light is always there, i've tryed many many times to put a scanner on it to fix the problem but people always tell me my car is ok, i even take it to the chevrolet and they told me they dont have a scanner for 96 blazer, i never had any kind of problems with my blazer, but like 6 months ago it has some problems, its hard to start, after i start it i have to wait 10-15 mins to get a bit heated because if i try to go with the car cold it shut down, when im in a red light and i stop the car it starts shaking so i have to accelerate because if i dont accelerate it shut down, i already changed the fuel bomb and the battery of the fuel bomb, but the problem stills there, i think the problem is the maf sensor, i really don't know what to do, can you guys please give an advice since i can't put a scanner on my blazer
PS: btw sorry for my bad english since im from venezuela
**sorry i think this post is in the wrong section, but i will keep it here bec i dont want to double topic, sorry guys
Old Jun 24, 2011 | 11:10 AM
Diagnosis starts with getting the codes read. There should be nothing about scanning a 96 than say a '00. Both are fully OBD2 compliant (or should be). One thing that will prohibit the scanner from connecting with the vehicle is a blown CIG fuse. The CIG fuse powers the DLC (data link connector). Check that fuse and then see if you can get the codes read. If the CEL (check engine light) is on, there are codes stored.
Old Jul 2, 2011 | 03:26 AM
toxikchevy's Avatar
toxikchevy is on a distinguished road
That shaking could be in the transmission. Check all the main fluids and if your not sure have a buddy that it. Adding tranny fluiod could help your situation but check it first. Maybe add a quart or two. Your firing system might have a low voltage problem too. I doubt it but a topend tune up would hurt it at all.
Old Jul 2, 2011 | 05:32 AM
chevy92's Avatar
chevy92 is on a distinguished road
Check the throttle body and idler, mine is doing the same thing. Except the idler screw (and I think there is an "O" ring in there?) is worn out and broken.
Old Aug 24, 2011 | 08:56 PM
chevy92's Avatar
Does anyone know what the part number for a dome light in a 96 blazer? or if I can get a led light kit for it? my bulb is missing and I don't have the part number.
Old Aug 26, 2011 | 05:27 PM
LTodd's Avatar
LTodd is on a distinguished road
The timing could be off.
Old Aug 26, 2011 | 05:42 PM
aneill75's Avatar
aneill75 is on a distinguished road
I could tell you to check for chipmunks under the dash, but I'd be just throwing things at it, like others have done.
You're best bet, as Kyle has already mentioned, is to have the codes read, and see what comes up. 5 or 6 years with the MIL lamp on I'd like to see the mechanics face on this one
Let us know which codes are present, and we can help from there.
Aaron
EDIT: I see the original post is 2 months old........ I wonder if Luis92 got his problems sorted out. I guess will have to wait and see.
Old Sep 6, 2011 | 12:44 PM
chevy92's Avatar
Yeah, I figured out the idling problem, and it's not the throttle. It's some gray box on the firewall that controls the idle speed, a mechanic said there was an O-ring gone bad on it and the cover isn't stayin on to well, but that's my problem Luis92's might be different. Oh and use electrical tape to tape over the "fix engine" light, trust me, it works.
MyBlazerSucks
Jan 5, 2012 12:02 AM
English5
Jul 16, 2010 11:11 AM
soky25
Mar 15, 2010 05:33 PM
Confuused69
Aug 2, 2009 11:53 PM
Daytripper540
Mar 29, 2007 03:54 PM
