L67 Swap in Blazer
Old May 21, 2012 | 10:21 PM
r0k0's Avatar
r0k0 is on a distinguished road
Default L67 Swap in Blazer
Want to swap in a 3.8L Supercharged engine in teh blazer for 2 reasons :
Fuel efficient and Higher stock HP / Torque
the 3.8L are easy to tune / mod for easy 300hp
any kits to get those bolted on a 5 Speed with 4X4 ?
Old May 22, 2012 | 08:47 AM
You would need to get the block out of a Camaro so that it would have provisions on the sides for longitudinal mounting.
Old May 22, 2012 | 07:28 PM
r0k0's Avatar
Camaro's had 3.8L Supercharged engines ?
Old May 22, 2012 | 08:41 PM
TripleBlackBlazer's Avatar
No, but they had 3.8 V6s that you could "top swap" the blower/heads/etc. to.
Old May 22, 2012 | 09:15 PM
No, they were naturally aspirated only.
^^^THIS^^^
What the Camaro 3.8L V6 gets you is a longitudinally mounted block (i.e. a block with bosses on the sides for motor mounts) that can accept the heads on up from the transverse mounted FWD motors found in the Grand Prix & Bonneville L67 motors.
To mate a 3.8L V6 to the 4L60E, you will need to swap the bell housing on your current transmission for a 60 degree V6 bell housing. Taking a bell housing from the same Camaro you pulled the engine block out of would work!
Old May 27, 2012 | 10:07 PM
Logan's Avatar
Logan is on a distinguished road
Hmmm... What would be more worth it... 5.3L or 3.8L???
Old May 28, 2012 | 05:31 PM
r0k0's Avatar
for me i'd love the 3.8L supercharged
Old May 28, 2012 | 06:13 PM
AJBert's Avatar
Just give me an LS1 and I'll call myself happy. Had one in a '98 Camaro SS and that was the sweetest running engine I've ever had the pleasure to push the skinny pedal on.
And counted in those engines are more than a few big blocks from the '60's/'70's.
94BlazerGirl
Aug 28, 2014 06:14 PM
jjstyle
Jul 29, 2014 06:53 PM
PogiMoto
Jun 2, 2014 11:31 AM
Phillips8201
Mar 16, 2010 10:26 AM
02 Vortech
Engine & Internal
Mar 7, 2005 10:41 PM
