Lousy Gas Mileage
Old Mar 1, 2011 | 07:57 PM
Hernandez_2007's Avatar
Hernandez_2007 is on a distinguished road
Default Lousy Gas Mileage
Ok, here goes: I just recently had the fuel pump and fuel filter replaced in my Blazer, as well as a tune up and an oil change, but my gas mileage has gotten worse. I was told that it may be the fuel pressure regulator. Any suggestions?
Old Mar 1, 2011 | 08:04 PM
Have you tested your fuel pressure?
Have you run any injector cleaner through? A double dose of the 20gal treatment bottles of Chevron Techron Fuel System Treatment Plus may clean up the injectors/poppet-nozzles.
Are there any stored OBD2 trouble codes?
Old Mar 1, 2011 | 08:45 PM
Thanks for the response. I am not sure if the lines were tested and have not run the injector cleaner yet, but will do that tomorrow. And I am not sure about the trouble codes.
edacsac
Aug 13, 2008 10:07 PM
BlaZeR FXB1581
Engine & Internal
Oct 13, 2005 01:30 AM
RedBlaze
Aug 2, 2005 10:03 PM
2001Blazer4x4
Engine & Internal
Aug 1, 2005 01:23 PM
SEDOC
May 26, 2005 05:46 PM
