peformance ignition coil
so, when i do my ignition service, just leave the coil alone and just do the cap, rotor, wires, and spark plugs? i've heard that ac delco are the best for our truck. with that being said, does ac delco make any preformance version of the stock parts or would someone have to look else where.
the ac delco info came from my dad who has own many gm cars/trucks and said that the engines are desgin for the alone ac delco parts(spark plugs). can someone clear me up on this?
You cannot go wrong with AC Delco ignition parts. I like the Belden Premium wires from Napa though. Napa Echlin (sp?) line of ignition parts are not all that bad, but if you are getting the cap there, get the one with the brass terminals.
You likely had a problem with your old coil then or you had the older ignition system.
Hopefully it stays working well for you. I have heard and experienced longevity problems with MSD direct fit coils in newer vehicles. My old 2001 Bonneville SSEi worked quite well with them for about 3 months and then one failed. Another 2 months later, and then the last one 4 months after that. I got free replacements each time, but I ended up selling them and going back to stock.
Then I put the 6AL box on it - Boooyah! Torque out the "A" double snakes!
If you run an aftermarket (hotter) coil, don't you need to open the plug gap? If so, do you run a risk of burning the tops of the pistons in a DD? Im not real familiar with whats inside these stock motors but, Id like to go to a 6AL set up.
poertsch
Performance & Brainstorming
Mar 4, 2014 04:53 PM
Lancealot
Feb 22, 2011 07:34 AM
