relieving Fuel Pressure
Old Aug 1, 2006 | 02:28 AM
PER10DER's Avatar
PER10DER is an unknown quantity at this point
Default relieving Fuel Pressure
I want to change the fuel filter in my wifes blazer. The haynes manual talks about connecting a gauge somewhere and finding some valve somewhere. What I have done in the past is pull the fuel pump fuse and let the vehicle stop running and it's depressureized. To pressureize reconnect fuse. I am new to domestics, I have only worked on improts before.
Will this work on the blazers?
I have heard rumors of vehicles costing a fortune to get running again if run out of gas. I have never had that happen to me I just dont want to learn the hard way.
Old Aug 1, 2006 | 08:06 AM
Default RE: relieving Fuel Pressure
Yup, it's what I do. Pull the fuel pump fuse and start 'er up. Well, you won't be able to get it to run, but it will depressurize the system for you. Expect a certain amount of fuel to come out (from the volume in the lines), but atleast it shouldn't spray out at you.
Old Aug 1, 2006 | 12:31 PM
PER10DER's Avatar
That's what I thought. Thanks for the reply.
brianroark
Jun 25, 2010 03:14 PM
Spartan66
Jul 11, 2008 02:34 PM
riverjamie
Sep 24, 2007 08:21 PM
aspenpup
Sep 9, 2007 07:11 PM
jlinder
Aug 21, 2005 11:08 AM
