rough engine
Old Jan 22, 2007 | 01:41 PM
jimmyboy's Avatar
jimmyboy is an unknown quantity at this point
Default rough engine
i dont know what this could be or how to descibe it other then it sounds like i put a race cam in. but it doesnt do it all the time just every once in a while. the guy at work said it could be a cat. any ideas?
jimmyboy
Old Jan 22, 2007 | 01:48 PM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
Default RE: rough engine
First off I would try to stop at an AutoZone or like part store to have it code checked
Second w/ Dynomax Bolt on Cat (Super Turbo) pending on when you installed this, I doubt it would be your cat if it was fine for at least 2 mths after you installed this.
Third I would have your Fuel PSI checked
It could be anything from a bad plug wire / bad injector / plug / fuel filter ect.... there have been many Q's about rough idle and such. Its best to start off with scanning for codes first. Then go from there.
RandyRhoadsFan82
Mar 29, 2014 11:22 AM
blazerguy22
Nov 14, 2013 11:50 PM
nhguy261
Dec 30, 2010 01:41 PM
c10jm
Aug 12, 2008 05:34 PM
azblazer89
Jun 6, 2006 01:06 PM
