supercharger
Old 05-20-2006, 07:01 PM
blazerscooby's Avatar
blazerscooby is an unknown quantity at this point
Default supercharger
where can i buy a supercharger kit for my 97 blazer? thanks for the input.
Old 05-20-2006, 10:49 PM
Default RE: supercharger
I don't know if anyone specifically makes a s/c for the 4.3L v6, but due to the similarities with the 5.7L v8, a v8 centrifugal s/c should be able to be underdriven for use on the 4.3L. I would start by contacting ProCharger, PowerDyne, and/or Paxton. Both are manufacturers of belt driven centrifugal superchargers that should be fairly easy to adapt to the 4.3L v6. Some fab work may be necessary for brackets, etc.
*EDIT* - Ha... Well, I guess I was wrong... Here's Powerdyne's direct fit centrifugal application for the 4.3L v6: Powerdyne K10525-101 - $3800
The others do not show applications for the 4.3L v6, but I'm sure that they could point you in the right direction.
Old 05-21-2006, 01:09 AM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
check out Mach Performance they have supercharger and turbocharger kits for the 4.3
Old 06-19-2006, 04:09 AM
LunchBox's Avatar
LunchBox is an unknown quantity at this point
I don't recall what year model it comes from, but the Pontiac Grand Prix GT was based on a 4.3 platform with a supercharger...it's supposed to bolt right up. If you don't wanna break the bank, it might be worth looking in to.
Old 06-19-2006, 08:23 AM
ORIGINAL: LunchBox
Grand Prix GTP... Nothing in the 3800 S/C will bolt up to the 4.3L and there is nothing in common between the 3800 and the 4.3L. The 4.3L is based off of the 350 (less 2 cylinders) while the 3800 is based off of the buick 3.8L v6. IIRC, both the 3800 and the 4.3L are 90* v6s, but the bore centers are not at all the same so that right there throws a lot of stuff out the window. Now if you were to have a custom lower intake manifold fabbed up, you can make anything fit. BTW, my summer time DD is a Bonneville SSEi 3800 S/C.
Old 06-19-2006, 10:34 AM
SniperX13 is an unknown quantity at this point
ok, what if anything with fit on the older generation 4.3L.... all those were for like 96+... I feel so left out...
Blaize70
Nitrous, Super Chargers, & Turbos
19
09-20-2008 10:23 AM
psyco1887
Engine & Internal
02-09-2006 01:09 PM
V6 Vortec Jimmy
12-02-2005 06:58 AM
GokuX
Engine & Internal
06-22-2005 04:09 PM
V6 Vortec Jimmy
04-01-2005 01:43 AM
Quick Reply: supercharger
